Question about Motorola Mobility RAZR V3
The buttons and the lights are turning on, but the
The buttons and the lights are turning on but the screen isnt doing anything.
  • Motorola Mob... Master
  • 641 Answers
Well there is a flex cable that runs threw the hinge to the screen.That is usually the problem,it cracks and wears out after time.Or possible the screen just went bad.There not expensive and very easy to replace
Posted on May 13, 2010
Inner display backlight works, but it doesnt display anything, could this be the cable sockets problem? Thank you for help.
If you look very closely (check in different lighting conditions), do you see anything on the outer screen at all? You probably won't be able to fix this yourself, but you might be able to determine if something is loose. Press a button on the phone, which would normally make the outer screen light up. Hold the phone firmly in one hand and smack it into your other, outstretched hand at different angles (i.e. smack the right side, left side, top, etc. several times). If the screen comes back on even for a moment, then something is just loose, and the repair shouldn't be costly. If you can see a faint image on the screen in some lighting condition, but smacking the phone doesn't help, then the problem is the backlight and you will probably need a new screen. If you can't see anything on the screen at all, and smacking doesn't help, then the problem is unknown
go to nokia care
Nov 22, 2014 | Nokia E90 Cell Phone (Unlocked) - Black
My iphone is acting weird. Every screen is moving around a bit. I didn't do anything to it it just started today.
Well if it looks like the icons are "wiggling" than you just have to hit the home button and that will go away. If this isnt the problem i would suggest a soft reset. Hold your power and home buttones down until the screen turns off, then keep holding. The apple logo will pop up again if done correctly, once you see the logo you can release and your iPhone will boot properly.
May 10, 2010 | Apple iPhone Smartphone
My voyager's inside screen has gone black
do the buttons on the inside work? if so maybe you dammaged the video cable to the screen. if the buttons do not work then the phone isnt recognising that you have opened it. does the external screen go blank when you open it?
Jul 23, 2009 | LG VOYAGER VX10000 Cellular Phone
My ipod isnt repsonding at all, the screen is lit up and the button isnt working. I can't do anything on it! Help!
Do a reset.
Move sliding switch to the left.
Hold down the centre button.
Press and hold down Menu.
When the apple logo appears let both buttons go.
Jul 08, 2009 | Audio Players & Recorders
Iphone breaks again
Holding the power and homes buttons to hard restart the iPhone takes about 10 seconds.
If it really won't turn off that way but it will connect to your computer, try "Restoring" it. Hopefully you've already synced/backed up all of the info on your iPhone.
BTW: You mentioned that this has happened before? What have you done, tried, etc... in the past?
Please feel free to call me anytime for more help.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 08, 2008 | Apple iPhone Smartphone
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
LCD Screen stopped working on camera.
Have you tried the 'Menu' button? If you've turned off the 'Review' feature in the settings menu, your LCD screen won't show anything unless the 'Menu' button is pressed. If it doesn't come on when you push 'Menu' with a charged battery installed, your camera will need to be serviced.
Dec 25, 2007 | Nikon D40x Digital Camera
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
