Question about Edimax BR-6104K Router (br6104k)
Port Forwarding with BR-6104K
Hi
I've read the article by wikihow below but it didn't help. I have enabled Port Forwarding, entered my IP taken from ipconfig, set the port (UDP/TCP 6112 for Starcraft), saved settings and it's still the same.
Please help.
Ta
  • Alichino Mar 30, 2008
    Thanks but still I can't do it right.
    I have a cable modem, I set the static IP according to the instruction site portforward.com and nothing.
    On the Virtual Server/Port Forwarding tab on my router page what IP should I enter? My current static IP? That didin't work...
    Also I only got one DNS address and it's same as default gateway.
    Windows XP SP1
    Scholar:
  • 35 Answers
Hope this helps
In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
I have not run into CABLE providers cable modems having to do this
did you allow that port in your computers firewall?
Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
instruction site
http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
Posted on Mar 30, 2008
  • Anonymous Mar 30, 2008
    what OS are you using?
SOURCE:
How to Watch Security Cameras on the Internet (Port Forward IP Cameras)?
what sort of router is being used ?
are the cameras on static ip addresses ?
google search for
model of router and port forwarding
http://www.wikihow.com/Set-Up-Port-Forwarding-on-a-Router
Oct 19, 2016 | Cell Phones
How do I get my router add a new port forwarding entry - port 12345, protocol TCP. And how do I find out the IP address of my computer? Thank you for you your assistance.
To find the IP address your computer is using:
Windows XP/7
1. Click on Start > Run
2. Type cmd and hit enter
3. Type ipconfig and hit enter
4. The number on the right of IP Address is your assigned address.
To add a port forwarding entry, log into your Linksys device and try the following:
1. Click on the "Applications & Gaming" Menu
2. Input an application name (Can be anything you want)
3. Enter the desired port number [12345] in both External and Internal Ports
4. Choose the TCP protocol
5. Enter the last number of the IP Address in the box
6. Click the Enabled check box
7. Click on un7bpgedqyopdk0zbwaaaabjru5erkjggg== on the bottom
Sample of Port forwarding menu
vnplpartunolz7n6n3b9m+jnn7ml0i2nqxyrocyd25orpdehebgvt+6hh5hgnu0+edcks7p0pdwicsaoso4igridejiaikycxiwjccv4h6gesrve+m0iaaaaasuvork5cyii=
May 03, 2011 | Linksys WAG200G Router
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
Asks for IP address and password
Try reading the Quick Installationguide and see of that helps.
http://www.edimax.com/images/Image/QIG/Wireless/BR-6204Wg/BR-XXXX_QIG.zip
Nov 03, 2008 | Edimax BR-6104K Router (br6104k)
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
How to config my edimax 6104k router???
1You can run the setup CD or manually configure it using the user interface of the router.
2.Since that is a router all devices that will be wired to it should automatically get an IP address from it.
3.Since they will be connected to the router you just need to enable file sharing on each computer.
May 07, 2008 | Edimax BR-6104K Router (br6104k)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
How is Port Forwarding Configured?
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear (RP114NA) Router
Port Forwarding
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
Edimax BR-6104K Router (br6104k) Logo
438 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Ekse
petrumusic
Level 1 Expert
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
