Question about Ingersoll Rand Standard-Duty Multi-Purpose Air Angle Die Grinde
Where do you find rebuild kits for the 301 angle grinder
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
I have a dewalt 28402 grinder. I have replaced the pinion but I don't know how to get the helical gear out of the case to replace it. Any thoughts? Thanks Chris
You can buy the pinion gear as a seperate part but not the ring gear. Dewalt only sells the ring gear as a part of the gear case assembly, PN 623586-00.
Oct 28, 2010 | Dewalt D28402K Heavy Duty 4 - 1/2" Small...
I have a Makita 100mm Disc grinder what attachments are available for this older tool...model M952
as its a grinder...there are not many attachments available....just your common grinding and cutting discs.
Aug 06, 2010 | Makita 9553NB 4" Angle Grinder
Fault on a Kinzo 115mm Angle Grinder
Hi J,
Hopefully you just wore out the brushes. Replacement kits are available for a few bucks and the fix is pretty easy.
On the darker side, If it overheated enough that it burned the windings (insulation melts, shorts, badness), there isn't much you can do unless it's still under warranty.
You won't know until you get it apart. You'll know which it is at a glance.
Unplug it and dismantle the base of the grip where the cord is attached.
The brushes are small spring loaded graphite blocks that transfer electricity to what looks like a cylinder around the central drive shaft that has a lot of vertical copper strips on it. They are normally housed inside small copper tubes opposite each other.
If those tubes are empty but for the spring, it's brushes.
If the insides are full of ashy residue, it's not the brushes
Best regards and I hope it it's the brushes
Mike
May 27, 2010 | Dewalt DEWD28110 Heavy Duty 4 12"...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
I want to learn how to repair or rebuild makita grinders
i worked for makita factory service center as a senior technician and never heard of a video...
Apr 09, 2009 | Makita 9565CV 5" Variable Speed Angle...
I need to find a manual for the makita 18v lxt angle grinder. my problem being that when i put the battery on the lights flash up red and during use the lights do not work at all. please help.
Hi, Don't stress, its working fine. The grinder has a sort of self test when you put the battery in, it blinks. What you don't want is the light to come on when you are using it. That means that you are bogging it down and if on for 30 seconds ( if I remember right) it will shut the grinder off until you reset it by turning it off and then on again. So no worries!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 26, 2009 | Makita 18V LXT Lithium Ion Cordless 3/8...
Ingersoll Rand  Standard-Duty Multi-Purpose Air Angle Die Grinde Logo
Top Ingersoll Rand Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Vernon Taylor
Are you an Ingersoll Rand Grinder Expert? Answer questions, earn points and help others
