Question about Dishwashers
How to get new external heating elment nuts - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you with that...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Posted on May 14, 2010
How can you tell if a heating elment is not working and how many elments are there in a dyer
Electric dryer? If it doesn't heat at all it is most likely shot. You have one heating coil in the rear of the dryer. You will need to take it apart to get to it. You will notice if the coil is broken once you visually inspect it.
May 03, 2017 | Dryers
Dryer wont heat. how can I tell if it is the heating element
If there is no heat at all, it is the heating elment is most likly broke a wire in the elment. Be safe. Vern
Apr 26, 2014 | Dryers
My dryer wont heat up its not the heating elment
If the heating element is good, then you need to check the voltage to the element. I would first check voltage at the heating element connections, should be 220 volts.Then work back through the start switch and dryer selection switch.
Jan 10, 2011 | Dryers
How do you replace the heater coil on this unit
First of all you did not even begin to mention a model number. They are not all the same. Having said that the concept of changing a heating element is pretty much the same for those with through the lower tub mounts.
1. Turn off all power to the unit
2. Open the lower kick panel
(It is usually in 2 pieces) The top piece being fixed and the lower piece being adjustable to the floor. Remove BOTH panels.
3. Locate the 2 heating element terminals that pass through the bottom of the tub and disconnect the wires.
4. Losen the retaining nuts on the heating element. Push up on the elment to make sure it is free before totally removing the nuts.
5. Remove the nuts and then lift out the old element by opening the door and lifting out the element.
6. Note the position of seals and washers on the OLD element
7, Assemble the new element with the tub side seals and washers. Leave the under side washers off until after you place the new element in the dishwasher.
8. Install the underside seal and washer then install the nuts loosely.
9. Check the position of the element inside the tub. (Align as necessary)
10. Tighten the heating element retaining nuts on the under side of the tub. (DO NOT over tighten as you can damage the element.)
11. Install the 2 heating element terminals makeing very sure the connections are TIGHT. A loose connection will cause the new element to fail prematurely.
12. Connect power and test for leaks.
13 Leak test complete install both lower kick panels.
Task Complete!
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Kenmore Dishwashers
Leaky heating element
their is a nut right in center of heating element. loosen it and push heating element a little in and tighten bolt. that should work.
May 17, 2009 | Kenmore Elite 45986 Front Load Washer
Oven elment wont turn on
you probuly left one of the wires off in the back or another wirer came off when u replaced the last elment
Feb 08, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Electric heating elment.
Somewhat,
I have a ref. thermometer, round metal type I got a Wal-Mart that I check the dryer temp at the discharge. I bent the metal bottom so I can lodge it in the discharge pipe, turn the dryer on and watch the temp. Normally on high heat it will go up to 140-150 and cool down to 120-125 then cycle back on.
Jan 24, 2009 | Estate EED4300SQ Dryer
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
