Question about Toshiba SD-3980 DVD Player
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
My Toshiba DVD SD-3980SU2 or SC2 player is calling every disc I put in.. a BAD Disc and will not play them. This just started yesterday. Please help... or advise.
  • 6 more comments
  • Rich22049 Apr 01, 2008
    Calls every disc a bad disk
  • Anonymous Apr 27, 2008
    The same thing has just happened to ours.
  • soybomb70 Jun 04, 2008
    mine does the same thing. i haven't been able to figure it out yet. help!
  • ddoherty12 Jul 20, 2008
    Every disc I load tells me it is a bad disc....I purchased a "cleaning" disc but it will not even allow that disc to work....help.
  • Anonymous Aug 28, 2008
    My player is doing the same think + the drawer often won't open either. what's the 1-800 Toshiba number? I likely won't be buying another Toshiba.
  • cimason100 Nov 24, 2008
    Every DVD comes up as a "bad disc" on my Toshiba DVD - what can I do to fix it?
  • Anonymous Jan 25, 2009
    Does it work to unplug the unit for 3 minutes (like the call center suggests)? Will the people at Toshiba follow through with repairing this "bad disc" message, which everyone has to face as an owner of the SD-3980 DVD player? Anyone had success yet? TOSIBA'S CONTACT INFORMATION: Hours of operation, repair/product dept., are; Mon - Fri > 8AM - 7PM (CST) Email: [email protected]
  • stephenb842 Apr 14, 2009
    Defective junk acknowledged by the manufacturer. Toshiba will replace it IF AND ONLY IF the model number ends in SU2. If yours ends in only SU, like mine, no replacement is available. Instead, you can pay to have Toshiba service a defective product. No thanks. Instead, I will choose to never buy Toshiba again and tell everyone willing to listen that Toshiba will manufacture a defective product and not stand by it.
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players Toshiba DVD SD-3980SU2 or SC2  player loads every  - spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
Hey, just read a Toshiba announcement about this subject and it is a piece problem so you shoul contact the 1-800 number for a possible replacement of the unit. good luck
Posted on Aug 03, 2008
SOURCE:
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Apr 22, 2011 | Toshiba SD-3980 DVD Player
I have a Toshiba SD-4000KU dvd player which worked fine but is now not loading and just says bad disc with a perfectly good disc what solution is there to rectify my problem. Thanks
Just wondering whether damp has affected the circuit boards.
Try putting it in a warm room plug it in and leave for 2 hours then try again.
Nov 13, 2009 | Toshiba SD-4000
When I put the disc in it starts to load and tehn a messagE " NO VALID DISC"
Maybe the file format is not supported or the disc might be in bad condition. Try using lens cleaning disc.
Nov 06, 2009 | Toshiba SD-3980 DVD Player
Toshiba DVD player doesn't retract or load media. DVD carrier is stuck in the out position
There is a rubber band on the motor that opens the tray out to load the disc, somehow that must of slip off the motor. Or the motor itself went bad.
Oct 11, 2009 | Toshiba SD-5700 DVD Player
Screen on TV shows Toshiba label and says there is no disc but a disc loaded in it
The laser unit has gone bad. Usually it's not worth replacing as it is about 3/4 the cost of a new player.
Jul 25, 2009 | Toshiba SD-3990 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD-K850 trouble
I contact Toshiba Service and they suggest to unplugg AC cord then wait for 3 minutes but this is not a real solution ("Bad" message). I already notice other Toshiba models have the same problems (SD-K750 & SD-3980), and they are replaced them because of component part failure. (my DVD is a SD-K850).
They also explain that if that process not work, I must call their
Service Dept. for more details, same phone # (1-800-631-3811).
Luck!
Oct 21, 2007 | Toshiba SD-K850
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-3980 DVD Player Logo
2,317 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
