-   My detergent capsule gets kicked out and never dissolves so the dishes don't get washed. Not every appliance repair shop fixes Bosch I am finding out. This is not my model but I am having the same problem.-   Incontempt
May 03, 2008
-   i have a bosh dish washer .recently the soap dispencer never opens during wash cycle.-   Guest
Disassembled solenoid, found plugged inline strainer (caused by water shut-down in building to replace recirc. pump) Pulled and flushed filter basket, problem solved. Solenoid must be removed to access filter which is in sol. body. I hope this can help anyone who does'nt have a tech manual or flow diagram.
our fitted bosch dishwasher does not wash ok soap half left it goes on and on cleaned outlets etc and it works approx 3 times then old problem comes back
Bosch SHU99.... At the end of wash cycle and unit is done...when you open up door, there is soapy foam on dishes. Other wise, dishes are very clean. Just does not rinse completely. Any help?
I found that by initially disconnecting the pipes and cleaning them out (without the usual...
(More)
I found that by initially disconnecting the pipes and cleaning them out (without the usual success)......then taking the front door panel off (you need to carefully remove s/steel screws from inside which then release the white or outer door panel) i found an accumulation of 'gunk' inside. Clean all of this out, make sure that rubber surround seal is 'secure' and that all inner water carriers (to tablet flap) are leak-free......re-assemble....try it!....mine is now 'as good as new' (4 back-up washes done!). good luck (POWER OFF WHEN WORKING INSIDE DOOR...WIRES!!!!!!).
