Question about 2-Way Remote Starter
I have a 2003 Jeep grand cherokee . It will start with the remote starter.it will also start with the key but will not continue to run.can this be due to programming?
    Problem Solver:
  • 7 Answers
Check the wiring, had similar problem on my 2000 Crown vic
Posted on May 14, 2010
2000 jeep grand cherokee 4.7 has a no crank no start on cold mornings
DOES IT CRANK in NEUTRAL? using fresh PRNDL contacts?
no crank, is easy to diagnose. with just one tool a voltmeter.
12.6vdc is a charged battery , rested, if lower, and not cold its discharged. so charge it or jumper cable crank engine off running donor car. easy huh?
if it cant crank it cant start, (mine can push start or gravity start)
battery cable lugs clean and tight x4 ends? green corrosion?
we then hot wire. the starter solenoid, next. (using old screwdriver as jumper bar)
it cranks now (good starter ) all in 5min work !
it does not crank bad starter.
so it cranks hot wired. good.
so next what is next, easy the KEY line.
the key line runs form the starter to the PRNDL switch and then the KEY switch (crank Start line)
if the car has SKIM immobilizer it cuts fuel not spark.
so i check for 12vdc into PRNDL cranking then key is ok.
if got 12vdc in to PRNLD but not out cranking the switch is bad.
or maladjusted?
its that simple ,with any 10buck DMM off walfarts shelf.
if car is hacked or alarms spliced in, we cant fix it here, its not stock.
same with remote start hack jobs.
Jan 27, 2015 | 2000 Jeep Grand Cherokee
How to disable the skim in a 2003 jeep grand cherokee
use the auto lock on your keys to lock and unlock this should fix it
Feb 14, 2013 | 2003 Jeep Grand Cherokee
Keyless remote 1996 jeep grand cherokee laredo programing
Instructions
  1. Programming the First Transmitter
    • 1
      Unlock all of the Jeepicon1.png Grand Cherokee's doors and open the driver's side door. Keeping the door open, lock it using the manual lock on the door itself.
    • 2
      Put the manual key into the ignition and switch it to the "On" or "Run" position, whichever applicable, without starting the engine.
    • Sponsored Links
    • 3
      Point the remote at the receiver (located by the little bulb on the caricon1.png ceiling) and hold down the "Lock" button for up to 5 seconds.
    • 4
      When the driver's side door unlocks, you know the remote has been programmed correctly. If you are only programming one remote, jump to the next step. If not, manually re-lock the driver's side door and repeat steps 5 and 6 using each remote you would like to program and then continue.
    • 5
      Turn the key to the "Off" position and turn the ignition on immediately. This must be done within 20 seconds of programming the last remote. You're finished!
Sponsored Links
Read more: How to Program the Remote on a 1996 Jeep Grand Cherokee ' eHow.com http://www.ehow.com/how_7433787_program-1996-jeep-grand-cherokee.html#ixzz2KdCc5PQq
Feb 11, 2013 | 1996 Jeep Grand Cherokee
Jeep wants to start with no key
If there is a remote engine starter installed in the Jeep, it might be malfunctioning and trying to start on it's own. Also, some remote start units have a timer or temperature sensor that starts the vehicle automatically if the temperature drops too low.
Jan 23, 2013 | 1993 Jeep Grand Cherokee
2003 jeep grand cherokee will not start.
does is crank but no start,and are you getting spark to thw start plugd
Oct 29, 2012 | 2003 Jeep Grand Cherokee
2003 jeep grand cherokee , first time jeep wont start and the no key light is on. Do the keys that have the chips in them need to be replaced from time to time?
no. those chips does not need to be reprogrammed in time. (it is supposed)
go to dealer and ask them to reprogram your whole antitheft system(immobilizer too)
plus put new batteries to your keyless remote controller.
Nov 07, 2011 | 2003 Jeep Grand Cherokee
I have a jeep grand cherokee laredo 1993, the security system have been activated and now when I start it, it will only stay started for a few seconds. tried turning the key all the way to the right and...
first use your remote, lock-unlock-lock-unlock 5 times. use the key to unlock the door. lock with remote. If this fails, disconnect battery for 5 min. reconnect, should reset control module..
Dec 09, 2010 | 1993 Jeep Grand Cherokee
I have a 2003 Jeep grand cherokee . It will start with the remote starter.It will also start with the key but will not continue to run.Can this be due to programming?
No this does not sound like a programming issue, disconect the ground when running wire going to the bypass module and start your jeep with your key, if it continues to run you either have a faulty bypass module or the remote starter unit it sending a ground the whole time, which would keep it on and give the jeep 2 transponder signals when you attemp to start it with the key
Mar 19, 2010 | 2-Way Remote Starter
Wont start with key but will start with remote starter, any suggestions on what the problem is
Yes the brain to your alarm system that controls this remote starter has probably failed.
Feb 06, 2010 | 1996 Jeep Grand Cherokee
2000 Jeep grand cherokee limited remote start
higher end starters will have the lock/unlock/panic buttons built onto their fob. as for the seats... I dont know why it would interfere with your settings, but who knows... better to ask the seller of the remote start system.
Mar 18, 2009 | 2000 Jeep Grand Cherokee
2-Way Remote Starter Logo
181 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
