Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
  • Fisher and P... Master
  • 3,247 Answers
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
Posted on Jul 08, 2010
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher keep beeping F1 and F5
F5 is the fast and rinse LED
It simply means the lid motror current is to high during the start - The lid is jammed up or down. Or the electronic controller has failed!!
Dec 29, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
Fisher paykel dishdrawer keeps beeping with f1 error
http://www.scribd.com/doc/6462163/DD601V2-Manual#fullscreen
Nov 17, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Hey got a set of dishdraws and when ever we turn on it starts beeping and flashing F1
F1 Error is the Flood Switch. This Usualy mens there is a leak that has Triped the flote switch.
There are many things that could be leaking to cause this.
You should have a pro look at this machine.
Aug 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher&paykel d603 dishwasher
Disconnet Dishwasher, Remove lower dishdraw, soak up excess water with a towel, use a hairdryer to dry water especially under grey plastic cover. Then check seal on either dishdraw and make sure they are not kinked or leaking as this has most likely caused the problem. Power up problem should be resolved. Don't leave dishdraw unattended till you validate problem definately fixed.
Sep 06, 2008 | Fisher and Paykel 23 in. DS603H W Built-in...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
424 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
