Question about IBM E74 17" CRT Monitor
Buttons for the screen are not functioning - IBM E74 17" CRT Monitor
  • 80 Answers
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
I kan't enter service mode panasonic 2330
Press the FUNCTION/ORIGINAL SIZE (ledger)/3 buttons in that order, and hold the buttons until all are depressed..Press and hold FUNCTION....then press and hold ORIGINAL SIZE (ledger)....then press and hold 3. The service screen will open with F(x) at top middle of screen.
Oct 11, 2014 | Panasonic Workio DP-2330 Printer
Lg w2343t monitor
try monitor on a different working desktop to see if it works, both on the external and internal video card ports. If screen menu buttons fails to respond, fault is either on menu buttons or you may have a burned out lcd screen, try a different monitor on your desktop pc to check its functionality. Monitor probably needs replacement.( It might not be burned out for you mentioned "no signal" error message appeared on screen, have the screen menu buttons checked)
Dec 28, 2013 | Computers & Internet
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.
You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.
Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.
Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.
Brightness/contrast - picture of half light, half dark circle
color - RGB picture
tracking - two squares on top on one another slightly off center
set-up- hand pointing left
You want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).
Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).
Press the menu button again and that should do it.
Feb 10, 2013 | Gateway HD2201 22" LCD Monitor
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
Aug 29, 2011 | Akai LCT3201TD 32 in. LCD Television
It shows power saving mode
Power saver modes on the monitor has several functions. First the power saver preserves the devices from consuming current while viewer is mometarily away. Screens that display power saver modes returns to regular viewer mode soon as the remote controls or buttons are manipulated slightly as indication of request to regualar views. The power saveer mode of the screen can be disabled. Obser ve the feature functions of the device iether on the remote controlof device buttons. Power savers perform simialr to screen savers or device feature manipulations. Access the devices settings or menu buttons to display the entire list to buttons for disactivation of power savers modes. Usually the power saver mode may be onsctruting viewer experiences for situation that momentary displays ate idleness requiring to retore to viwer display screen. Refer to the devices userguide to attain details.
Feb 08, 2011 | LG Computers & Internet
Picture not adjusting to full screen an dmonitor buttons Exit, brightness, contrast and Menu are not working also. Checked all buttons contacts are ok.I tried to search for vertical and horizontal variable...
You will need to reset the resolution to fill the screen. That is done through Windows.
If the actual menu buttons on the screen are not working, you probably need a new monitor.
var fctb_tool=null; function FCTB_Init_5ddec69ff7a64d918e9c62baf4d86075(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_4b77af1c80d64567931291644b9994c7(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell E773C 17" CRT Monitor
My phone is SAMSUNG GT 19000s' I lost the user manual as I was travelling, I cannot receive calls. please tell me how to use my phone.
Give the phone a thorough examination making notes about where the power buttons sitauted along with important recogisable feature buttons that could come handy. Once comfortable with the button areas around the phone, first power on by pressing firmly on the on/off button and releasing mometarily. The phone should display lighting features, with a tone as the process takes places depending on the settting before condition was occurred. A which point, the phone would have displaye d a light screen with touch screen functionality. A queen observation makes availabe the phone call icons, end call icons, and additional icons of functionality. The phone could have a menu button controlling the entire functionality, where a press to release would would display every possible logos of icons, among which internet, web tv, settings, contacts are only observabel features fo functionality once the menu buttons been pressed while phone is powered on.Every additional functionality should be adjsutable. locate the manual for detail instructions on manipulating the device or contact the venders for technical support.
Dec 04, 2010 | Cell Phones
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
IBM E74 17" CRT Monitor Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
