Question about Amana ACS3350AS Gas Kitchen Range
Control panel when the oven gets hot the control panel will go out found a bad contact at panel need to know how to get the control panel out
  • pchaitman Nov 20, 2008
    Control panel seems to short out when temp reaches about 350. The exterior top of oven near panel feels very hot. After cool down oven is able to be restarted, apparently a control panel issue.
The control panel getting hot may be caused by the hindges on the oven door. I had my range serviced and when the door does not close all the way, then the hot air rises and basically cooks the control pad.
I just posted too with my frustration on this range.
Posted on Apr 16, 2008
"Amanda" ARDS802E. Why won't it heat?
Becky, it sounds like you have either a failed ERC or Electronic control board (Y0315030) or a bad limit control switch (31933003). If it's the ERC it's likely bad relay(s). If your clock is powering up and you see the clock then that lets us know that you are receiving power to the oven. If it's the Limit Control, then you will need to replace that approximately $60. It's inside the oven and prevents the elements from getting hot if it breaks. If it's the ERC then you can have it repaired for $99.99 from The Repair Shack. The link for the repair service is: Repair Service For GE Oven Range Control Board Y0315030. Hope this helps!
Nov 29, 2015 | Ovens
JTP15Wd1WW electric wall oven start button not working
I ordered a new control board and it did not fix my issue, I found that my ribbon cable is touching one of the boxes and getting hot, when I bend it away from the board, my button works, I used electrical tape to keep it from touching. It could be just a bad ribbon cable instead which costs about 25.00 , you have to know the exact number of pins your unit will need
Jun 17, 2014 | GE JTP15 Electric Single Oven
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
GE j TP 86 oven wont heat
sounds like the hi-limit switch
Mar 02, 2013 | GE JTP86 Electric Double Oven
Oven elements warm but do not get hot.
whats the resistance on the elements, how many watts are they?
make sure all wires are good, could have one broke about half way. you will need to check the resistance on the elements. you need to actually check the volts and use whats its closer to 240/220 you will have to find out the ohms so you know the element will get hot. if all the wiring is good start with the elements, you need w/v will tell you the amps. e/i will give you ohms, just use the equations in the pic to figure out what you need to know. it as to have enough resistance to get hot
Mar 29, 2017 | Ovens
JGBP33 Get an F2 Error, oven gets warm but not hot enough to cook, will cook on broiler mode? Any help would appreciated.
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
defective. Check door lock switches.
measures resistance of sensor circuit , not actual oven
temperature.
Feb 06, 2011 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
O have a aoes3030e and neither the oven or the broil get hot the display shows 170 and you hear a click like something is coming on and then another click like something is going off i do not have any f...
the clicking noise is the relay on the electronic board . and i bleive that the hi limit has failed pt # R0702565 located bening the control panel on top of the oven .. ck htis before replacing other parts ( very common ) mm hope this helped . feed back pls
Nov 24, 2010 | Amana AOES3030 Electric Single Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Bottom heating coil not working in my amana oven.
Most likely the temperature sensor is bad. This is a small pencil shaped rod in the top of the oven.
Well, to ensure the temp sensor isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, then its bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the wiring and touch the probes from the meter to the contacts on the sensor. You can order a new sensor locally or from repairclinic.com. Let me know what you find.
Benjamin
Mar 23, 2009 | Amana ACF4215 Electric Kitchen Range
I have a whirlpool RBS245PDQ12
you probably have the clock set wrong and oven is on automatic.switch off for 5 mins, get your book out and reset the clock
Jul 06, 2007 | Whirlpool RBS275PD Electric Single Oven
Amana ACS3350AS Gas Kitchen Range Logo
471 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
