Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell Flat Screen Model 1907 FPt
Comes on for a breif second or two then image disappears. Power light still will be on.
  • omiesteve Apr 03, 2008
    Yes I have heard a small spark.
How to open and repair DELL LCD 1807 FPt. Thanks - minh
Posted on Jun 16, 2008
Appears you have an inverter problem. Do you hear any sparking?
Posted on Mar 31, 2008
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | Computers & Internet
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
DELL MONOTOR TURN ON POWER SCREEN COMES ON AND GOES OFF IN TWO SECOND AND POWER LIGHT IS STILL ON
may be your power screen time is 2 seconds through properties u can change the time
Oct 01, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
When I start my computer my Dell S199WFP Flat Panel Monitor does not go on and stay on. It comes on for about two seconds or and switches off. I have to turn it on about 20-30 before it will stay on. While...
Hello
You have capacitors on the monitors power supply that have changed value. Soon they will keep the monitor from turning on at all. Send it to a company like mine or take it to a local repair person.
Aug 02, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Whats the meaning of a Dell Ultrasharp FPt 19" Monitor and a FP
It just the teminology used in dell flat panels e.g. FPT and FPV
FPV ( flat panel with Vesa mounting holes)
FPT ( Flat panel with Tilt adjust )
Thanks
proton
Nov 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
I want to connect a Ultrasharp 1907 FPt monitor to my Dell inspiron. I have a power cable and also one from monitor to lappy, do I need a driver?
to toggle the screen between your laptop and the dell 19" monitor. Hold down the Fn key on the laptop and tap the F8 key. The screen would move to the external display.
There are three settings that can be done by the Fn + F8 key combination
1. Both the laptop and external monitor works
2. Only the external monitor would work
3. Only the laptop screen works
Thanks
Proton
Dell UltraSharp 1907FP 19" LCD Monitor Logo
785 people viewed this question
Alun Cox
