Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Water appears to be leaking from bottom of door. Water is only on the front kick plate area
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
oitsaS
Posted on Sep 29, 2010
Water leaking on the front bottom wfs1273bw
What I would do is remove the kick plate at the bottom, usually held on by three or four torque bit screws located underneath, then run the machine. you can check the seal for tears,etc. This way when it starts leaking you'll see where or if its the machine, etc.
Apr 29, 2012 | Whirlpool Washing Machines
I have Maytag refrigerator model MZD2752GR. Water leak from under the refrigerator for about 5 min a few times every day. What is the solution to this problem?
There is no one solution to this. It come from a variety of ways. For example a crack in the defrost condensate pan. Or a leak in a water supply line. The way you described it is almost on a cycle basis so I believe it is more of the leaking condensate problem. I would like you to look inside the freezer and fresh food section bottom near crisper and look for condensate buildup inside these areas condensate in freezer would appear as too much frost on items in freezer and fresh food compartment like moisture collecting on walls and shelves. Do that and let me know what you see. Pull front kick plate in front off and pull away from wall. Remove rear cover on compressor area. I will return soon, Thanks, Sea Breeze
Apr 13, 2010 | Maytag MZD2752G Side by Side Refrigerator
Dishwasher is leaking from the bottom
Leaking Dishwasher
heatman101
vb
Jan 28, 2010 | Haier ESD200 Built-in Dishwasher
Dont know why turned the water on an pressed the water and nothing came out only at the bottom of the face plate. side by side
There is a plastic water tube that routs up through the door pedestal of the freezer door to supply the door dispenser with water, there is a quick disconnect down around the area that you say you have water leaking, I would pull the toe kick plate off and check that coupler for the leak. Good luck !
Jan 10, 2010 | Refrigerators
My d1716 continues to run, but does not move forward in the cycle. I can even open the door and it continues running. If I didn't unplug it, the motor would likely burn out. Do I need a new dial? Thanks.
Hi
I would suggest that your flood switch has been activated. There is a float on the bottom plate or base plate of the machine. If there is a water leak, the float rises and triggers the flood switch.
Once the switch has been activated, the machine will go on a continous pump.
Disconnect the power and the hoses from the machine. Pull the machine out and lay it on its back.
If there has been a leak, you will notice water pouring out the back.
See if you can open the bottom plate, and reset the floater and flood switch. Sometimes you can access this by openning the front kick plate or front bottom plate.
Try the machine again. Leave the front bottom plate out and look into the bottom as the machine is working. If you have a water leak, this will happen again and you may be able to notice where the leak is from.
Be carful not to touch the live wiring while you are monitoring the machine.
Good luck
Ash
Nov 20, 2009 | Asko D1716 Built-in Dishwasher
Leaks water
There are 4 screws holding that kick plate on. Normally, they're 1/4" drive. Lay on the floor with a flashlight and look at all 4 corners (between the kick plate and the door and near the floor).
This is how to get the panel off, but without a make and model I can't help any further. If you could provide those, we can figure out how to repair the leak. Just let me know, OK?
SG
Apr 05, 2009 | Westinghouse Dishwashers
Samsung fridge freezer mod no SRS2028 19.3 cu, ft
the water hose runs through the bottom hinge then to the dispenser. take the kick plate off of the unit and then check for leaks. theres a coupling down there that may be yoiur problem.
Dec 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Water Leak at bottom of unit
hi there,
leaks a quite frustrating once they happen but there aren't that many places that you can have a leak. i would recommend looking at the drain pump and ensuring all seals are ok. after that focus on the door itself. are the seals okay, the door liner, etc?
Nov 11, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Porche 911/996
check for door seal inside the door pannel specific area the lower part of the door /yes you have to remove the door pannel /////// if that does not work try the water drain on the front, below the battery remove battery plate and clean the drain rubber / the water runs all the way to the back from the bottom of he carpet
Jul 11, 2008 | 2002 Porsche 911
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
95 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
