Question about HP DeskJet 6122 InkJet Printer
HP Deskjet 6122 Paper won't feed
This printer tries to pick up paper, paper moves 1/4 inch and stops. I hear the rollers trying to feed the paper. If I manually feed the paper, the paper advances, backs up, then feeds all the way through with a 1/2" crinkle 2" from the left side of the paper. I get a blank sheet before every print out. This is the procedure for every page that prints. Any suggestions?
Thanks!
2 Suggested Answers
  • 27 Answers
SOURCE: hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Posted on Aug 10, 2009
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
When a page is completed the printer does not fully eject the paper and it and the next sheet gets crumpled and spoiled I am using hp deskjet 6122
Make sure the printer paper feed is not blocked with any paper. then check that the rollers are clean.
Also you need to make sure that the paper feed has the correct size settings (Usually a slide across guide labeled from a5-a4/letter)
Feb 28, 2011 | HP DeskJet 6122 InkJet Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
Hp deskjet 6122 paper feed
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
I have a HP 950C Printer And Am Trying To Print on photo paper
It sounds like the printers rollers are slipping on the heavier paper, possibly because this paper is smoother then your regular paper.
Try cleaning the exit rollers on the printer with something like methylated spirits - if the rollers have gone shiny, then you can usually revive them by using some emery paper to roughen them up.
Jul 08, 2009 | HP DeskJet 950c InkJet Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
My printer stopped picking up/feeding paper. If I
try cleaning the pick up rollers , they must be a little sticky
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 1280
seems like the pick up roller and seperation pad are dirty or worn.try cleaning them with nail polish remover. the roller is located at the bottom of the printer where the leading edge of the paper is the seperation pad sits under the pick up roller.
Nov 27, 2008 | HP DeskJet 1280 InkJet Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Paper won't feed
I replace feed rollers when this happens but you guys might want to try a slighty damp rag on the probally covered in paper dust feed roller.
Location underneath with cassette out.
Appearence larger Black Rubber cresent shaped roller inch wide front middle under.
Use damp rag water/metho
Nov 05, 2007 | Brother HL-2040 Laser Printer
HP DeskJet 6122 InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
