Question about Abit IS7-V Motherboard
Front USB I recently buy it and try to plug into front USB but it want work.Than I see that the cables didnt connected with board.I need a manual or advise to connect it properly. Thank you, Mickey
    Genius:
  • 1,027 Answers
The above is from the Manual if you need it let me know.
Posted on Mar 29, 2008
USB 3.0 connectivity to front on GA-Z68AP-D3
As you said the board got the front pin connectivity.
All you have to do is buy in any comp shop a front USB and sound socket for the casing.
It is up to you where to put it on the front panel, drill a hole to fit that outlet and use hot glue to fix it in that position.
Hope that helps!
Nov 21, 2011 | Computers & Internet
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
Hello, I recently purchased all new computer components, including a Diablotek EPIC ATX Mid Tower case. I have the system complete and running. At first I plugged a USB device into the front left USB...
Hi Red,
I had a similar problem on a different case though.They might have similar causes.
The front usb port circuit board was connected to the MB with a ribbon cable. The prior owner had the cable attached backwards. It worked fine, until you plugged in a USB device, instant crash.
Can't say for certain this is what is happening with you, but it is a possibility.
I'm sure you already know, pin 1 is the striped cable. On the board pin 1 has an arrow.
Best regards
Mike
Feb 05, 2011 | Diablotek CPA-802 ATX Mid-Tower Case -...
I want to connect My front USB to the Gigabyte MB ga-945p-s3 i dont know how to do it right if there is a video to show me how to do it, that would be great your help is needed thanks
There are two connectors on the motherboard marked F_USB1 and F_USB2 for the front panel USB ports. This is the page from the manual (you can download a copy here) for your board:
The pinout of each USB connector is the same, so it does not matter which one you use. Each connector supports two USB ports. The pin assignments are a standard, and the cable from the front panel USB connectors in your computer case may already have a plug on the end which will fit. Note the missing pin (pin 9); the plug is keyed so it will only fit one way so you can't put it on backwards.
If the front USB cable in your computer case doesn't have a 10-pin plug on the end, it will have a separate single-pin connector on each wire, and they will be marked with their function. Make sure you match each wire to the correct pin on the board, following the chart shown above.
You should have your front USB working very quickly. Thanks for using Fixya!
Dec 03, 2010 | Computers & Internet
How to connect front audio and mice cable jack with motherboard
Sorry, it has no front audio system! U have to connect at the rear and have to buy a speaker system w/ long cable wire! Use MOBO's USB outlet for the FRONT usb PLUG in using usb type mice! Taah!
Nov 12, 2010 | Mercury P4VM800M7 Motherboard
How to connect front usb to motherboard
First need to check front usb cable attached on mother board usb plug or not if its not attached so plug in to this pannel and then after you can access it.
May 09, 2010 | ASUS P5PE-VM Motherboard
Front usb configration
Just talking from my experience, I have noticed that some boards have problems with USB ports that are connected via a cable (yours is, I presume). Like the P5GC-MX I have in my CCTV server, the front ports only allow Flashdrives and low voltage devices but it doesn't accept USB Harddisks (those using laptop harddrives).
Can you attach flashdrives or is it really dead?
How about your pin connections? was it connected properly using the cable to the board?
What type of casing are you using? I noticed some cheap casings (those especially that don't use FoxConn, have problems with their front USB ports)
Sep 03, 2009 | HP Compaq d530 PC Desktop
QDI kudoz 7 mauanl wanted
this time your got have a spammer, i tell you read the USB port at the motherboard then put the wire connection there
Jun 17, 2009 | QDI Group QDI KuDoz 7 Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Abit IS7-V Motherboard Logo
85 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
