Question about Konica Minolta Maxxum 50 QD with 28-100 lens 35mm Film Camera
The data panel is not coming on. New batteries have been installed correctly but still not coming on.
    Problem Solver:
  • 14 Answers
If the lcd screen in installed correctly and still does not work. It needs a new board where the lcd screen is attatched.
Posted on May 22, 2010
My Garmin Geko 301 GPS Receiver will not turn on even with new batteries. I need to retrieve the data. I don't have an interface cable. Help anyone?
from what i have read you need that cable id try to find that cable from a retail source then try it,if you replace batteries make sure installed correctly and the contact areas are clean of all debris
Jul 17, 2016 | Garmin Geko 301 GPS Receiver
I haven't used the calculator in a long time(TI 83 plus) and I put in a new set of batteries. The old ones that were in left some battery acid, but not much. The calculator doesn't want to turn on. It's a...
hi adamsukienni,
Clean the battery damage up real good. Gently scrape to terminals of corrosion. Back in my day we use to put a little bit of coke cola to clean car battery posts to get a good connection. If you could put a little bit of coke on a Q-tip without getting any inside the calculator that would be good. Just let it soak in for about 30 minutes. And gently scrape the bad areas again clean of the corrosion. You have to clean it up to metal so, that when the battery is in it will be metal to metal connection.
If you can download new OS with another Ti83 Plus or, don't want to install the new OS goto Procedure 1.
Be ready to install the new ti 83 OS v.1.19. So, setup your computer with Ti Connect software and, have the new OS v.1.19 download ready and, in "My Documents \ My TI Data \ Downloads." If you need additional instructions on how to connect the computer to the calculator you can read my instructions at another posting I did. You can go to that posting by clicking, "Connection Instructions," under this paragraph. Just remember the OS was for a Ti 84 Plus and, your's is a Ti 83 Plus so, don't download the OS from the other posting. I'll give you a link below this paragraph to download the correct Ti 83 Plus OS v1.19 for your calculator here at your posting. Just follow the other posting to where I say, "You can also go back and, download the Ti 84 Plus guidebook too, if needed." After that statement the computer and, calculator get connected with the cable and, your not ready for that process, yet! When you come back to this posting and you have downloaded the new OS to the proper folder goto Procedure 1.
Additional computer to calculator connection instructions click, "Connection Instructions."
Ti 83 Plus OS v.1.19 download click, "Ti 83 Plus OS v.1.19". Save this download to "My Documents \ My TI Data \ Downloads".
Procedure 1.
Take all the batteries out for 10 minutes, including the very small one that you have to use a small philips screw driver to get it out. Watch out for the spring under the small battery, it might pop out. Replace all the batteries after 10 minutes with new ones, including buying a new small battery. The small one might cost about $5. I know it is expensive but, this might work.
A battery reset procedure should bring your Ti 83 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
If your Ti 83 Plus turns on when you put the batteries back in you do not have to re-install the OS. I just think it is better since, your OS might be corrupt.
The process below should reset your calculator.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done. Once again, if your calculator turns on after this procedure you do not have to re-install the new OS. You can quit these procedures now with a perfectly good calculator.
Please be prepared to re-install the calculator's OS, if you run through this process.
2). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Connect to other Ti 83 Plus and, install OS from that calculator. Or, follow the instructions, I gave at the other posting "Connection Instructions" to reinstall the calculator operating system and, connect the computer and, calculator. You can start where, I say, "Link your computer and, Ti 84 Plus (Your's is a Ti 83 Plus) with the proper cable (USB or Black Link). Upon completion your Ti 83 Plus will be ready to use and, the new OS installed.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
Hw to u my mobile as modem 4 this
If you can get the GPRS connection:
To activate the modem you install a USB data cable, install the driver to your laptop (from the Motorola website)
Then goto control panel->network places->create new connection->click connect to internet->click dail up modem->then ISP name->further setting!
Make sure you have installed the USB data cable and Driver correctly in your laptop,
Jan 05, 2011 | Motorola Mobility MOTOROKR E6
Remote sensor does not work after installing new batteries
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Oct 15, 2010 | ATOMIC Digital Wall Clock With Temperature
I hope this helps, go to your Menu and stroll down to the settings and make sure your Data Panel "View" is clicked on..hope this helps.
Mar 18, 2010 | Konica Minolta Maxxum 50 QD with 28-100...
How I can change the backup bateries
Find the correct replacement at Batteries Plus, Radio Shack,etc. Disconnect the red and black wires on old battery an install in correct place on new battery. Red is + Black is -
Jul 02, 2009 | Home Security
Mouse won't work after battery change
Are the batteries in correctly are there any indicators lit ?.
If not take out the batteries and try new ones
Once the indicators have come to life switch off your PC and put it on again , it should find the mouse itself
If not go into Control Panel , Add New Hardware and make the PC do a search
At some point it may ask if you have a disk , if you have say yes and put it in the CD drive
It should Auto Install from there
May 25, 2009 | Logitech MX600 9315951403
Wireless optical 3000 mouse not working
take the NEW mouse and re-install through the control panel option (for win +) or the correct procedure for the OS that you are using. the old one is likely dead. good luck!
Jan 18, 2009 | Microsoft Wireless Notebook Optical Mouse...
Usb modem moto
if u get the gprs connection! if it is activated mean! you install usb data cable driver to your laptop! then goto control panel->network places->create new connection->click connect to internet->click dail up modem->then ISP name->further setting! first install usb data cable cd correctly in you laptop!
thanking you
i think it will useful to you.....
Jul 08, 2008 | Motorola Mobility ROKR E6 Smartphone
Keyboard fault HP
instead finding printer driver, you should install first all the drivers of PC/Laptop. By entering some data about your PC/Laptop you can find your driver here: http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Please install the correct driver of your PC/Laptop to optimize its performance.
Jan 03, 2008 | Computers & Internet
Konica Minolta Maxxum 50 QD with 28-100 lens 35mm Film Camera Logo
Top Konica Minolta Photography Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
