Question about Westinghouse L2046NV Monitor
Screen dark and can barely see images - Westinghouse L2046NV Monitor
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Westinghouse monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 13, 2010
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
My lightning got really dark and i can barely see anything,i have to put the frame really up close to see a little bit.im not sure why it got like that.need help
LCD screens have a backlight. When the backlight starts to dim it will eventually completely fail, causing the image to be really dark, barely viewable. You will need to replace the LCD screen, or replace the entire unit.
Feb 17, 2011 | Philips 6.5-Inch Digital Photo Frame...
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Screen too dark, no setting can fix.
Sometimes the Screen (G2) control needs to be adjusted. This control is an internal adjustment that should only be attempted by a qualified person however.
May 02, 2009 | Hitachi 32UX01S TV
Dark screen on zen v plus
Was the device dropped or damanged? The most common problem is a cracked screen. The crack is on the back so you can't see it. The screen will need to be replaced.
Apr 26, 2009 | Creative Labs ZEN V Plus MP3 Player
Barely able to see screen.
Your screen or the inverter underneath it which controls the power to the screen is bad.
Feb 04, 2009 | HP Compaq Presario V2000 Notebook
Sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
Dark images too dark
Yes - go to mebu OPC off - and make sure active contrast is off in advanced settings
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Casio EXILIM 110 CAMERA
If you could still barely make out an image, but it is very very dark, then it sounds like the backlight has gone out...but the lcd itself is still working fine.
Feb 07, 2008 | Cameras
Screen on Toshiba M35x S149 Laptop blank/flickers
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
Nov 10, 2007 | Toshiba Satellite M35X-S349 Notebook
Westinghouse L2046NV Monitor Logo
139 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
