Question about Ovens
My Frigidaire Stove (M# - CMEF352CFS3, S#
My Frigidaire Stove (m# - CMEF352CFS3 S# NF81907833) has two problems. The first is that is that somehow the lock was turned on while the door is open and I am unable to turn it off. My second problem is that the indicator light comes on randomly and the oven will constantly beep whether it has actually reached the preheat temperature or not. Any help would be welcomed.
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
SOURCE: oven display not working/alarm beeps constantly/unable to turn on
oven display out when oven on alarm beeps wont shut off
Posted on Nov 22, 2008
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Posted on Feb 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Posted on Jun 26, 2009
protek480
  • 1714 Answers
SOURCE: Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Posted on Sep 17, 2009
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Stove timer frigidaire part #318011502
I want a timer no # 318011502 A Clock / Timer for Frigidaire model poile CFES388RE I want to know availability and price with delivery and taxes to address suivente comuniquer by iMail only I do not speak english
lucirfrancois@hotmail.com
Francois Simard
272 Archambeault
street
Alma Quebec
Canada G8B 7P7
46129e38-7280-4209-af5a-8221ee1faecf.jpg0b834c2d-f507-4cf5-ada7-21a37af0b5f7.jpg29d0c2b4-6e82-4ed4-858a-52b016f35b16.png
Jul 29, 2012 | Frigidaire Ovens
My frigidaire self cleaning stove(FGF368GM ) isnt lighting.... how do i light my stove?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire stove with oven
I have the same problem. Any resolutions for you?
May 08, 2008 | Frigidaire FEB30S5D Electric Single Oven
Ovens Logo
111 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
