Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
WD-62725 DLP TV Automatically Turns Off
After it is on for awhile, the TV will automatically turn to a blue screen, then it turns off and a green light blinks for about 1 min. then goes off. The time it stays on varies. I'm not sure what to do. Help!
  • padge23 Jan 18, 2009
    I have this same problem, TV is operating normally, then it goes to blue screen for a little while and then turns its self off. It is intermittent - can happen 4 times an hour or not at all for 5 hours. It seamed to start as the bulb started fading and I assumed that was the problem. I replaced the bulb when it finally went, but the problem remains. Another posting says it could be heat related, I did clean the filter when replacing the bulb.
Its usually your DM control board!!! it needs to be replaced!!!
Posted on Apr 08, 2008
SOURCE:
My Mitsubishi WD-62725 dlp powers up , no blinking lights, the screen on all inputs is blue with streaking horiz lines and snowball in center screen. Menu works, tuner seams to work but screen goes black...
Call Encompass Parts 1800-638-3328 or look them up online they list your TV as well as Service Manual and Keep in Mind just because Light Engine was replaced 3 months ago does not mean it cannot be same Problem so if you have any warranty on it replace it again!
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
May 26, 2009 | Mitsubishi WD-62725 62" Rear Projection...
My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Mar 18, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
197 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
