Question about Polaroid t1031 Digital Camera
Trying to charge the battery but can't slide the baterry in securely.
Same problem
Posted on Jun 08, 2010
Had to replace fuse inline alternator how can I transfer the inline fuse to a different wire
the cable /fuse to alternator has nothing to do with the start and run function if the battery is charged up and in good condition ,sounds like the main battery cables have a bad contact/connection or battery is shot<follow battery cables and remove all points of connection in engine bay area clean contacts with sandpaper and resecure all connections 1 AT A TIME! to make sure none are swapped around by mistake ) on both earth cable/negative and the positive/power cables,make sure terminals on battery are clean and tight , try boosting/jump starting your battery with jumper cables connected from another cars battery positive to positive .........negative to negative and see if it starts ,i doubt the problem of starting up is the alternator unless battery is flat and not being charged by alternator ,by jump starting with another baterry will give you the answer once all baterry cables and connections are clean and secure
Jan 15, 2014 | 2006 Ford Focus
Alternator wiring problem
check alternator main fuse is ok and check battery terminals clean and secured properly ,earth cable from battery to body and body to engine clean on contacts and secure ,if it still does not charge you can run a wire insulated from main connector on alternator straight to the positive of battery to rule out a break in power feed wire from alternator to the battery , is the alternator/baterry light staying on?
Jan 15, 2014 | 1998 Honda Accord
Sudden discharge of batteries
The icon may indicate the batteries are fully charged and your measurements would indicate this but I suspect the batteries are no good..
Nov 29, 2013 | Cameras
My laptop baterry indicator is blinking red
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 30, 2013 | MSI CR500-479US Notebook
Baterry isnt charging it only works on AC power DELL PP22L
Press the function and F3 button. This will enable/disable charging. If that does not work, then you either have a power adapter that is not creating enough voltage to charge the battery or the battery has gone bad.
Oct 21, 2012 | Dell PP22L-XT279 Core 2 Duo 1.6g 1gb Ram...
New baterry and alternator it crunk but wont start what is the problem
If battery and alternator are good is starter solenoid pulling in? it may be that whilst you have a new battery it may require charging new doesn't mean fully charged, batt may have been on shelf for awhile
May 01, 2012 | 1986 Nissan Pickup 4WD 1986
Blowing the fuse when trying to charge
I would think that a circuit is bad in the charger. Have you tried another battery?
Jan 29, 2012 | Ryobi Drills
Vtech camera - will not switch on. Have tried changing baterries and sometimes can get it to switch itself on when the batteries are changed but thn it will not switch off.
Have you tried checking if the battery door is tightly secured? Make sure it's completely closed correctly, the charge could be messed up. If that doesn't work, try cleaning doors and where the battery touches the door. Some dust particles or dirt can be on there and effect the power.
Mar 08, 2011 | Vtech Kidizoom Digital Camera
The baterry dies in 10 minutes.the motorcycle has only 6700km.should i change baterry?so soon?
Yes the battery can die in as little as 12 months if it is not used often, vibration and rough roads can also shorten battery life.
Check it has water in it up to the lines.
Put a multimeter across the battery should be just over 12v with engine stopped, rise to 13-14v with engine running to check charging circuit. Riding when the battery completely dies can overload the charging circuit.
May 14, 2010 | 2008 Yamaha XT 660 Z Tenere
Ducati Baterry issue
The battery can stay in the bike while charging.
Mar 13, 2009 | 2000 Ducati Monster 750 - Dark - City -...
Polaroid t1031 Digital Camera Logo
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
