Question about Amana AMV1162 Microwave Oven
Burning smell In normal use, microwave produces burn smelling but no smoke
  • jbedard Nov 05, 2008
    same problem but it's a GE microwave.
  • Cameron Scott May 11, 2010
    In the recent past did someone burn popcorn or other type of food? Microwaves will smell for weeks if this has happened, regardless of the food they are reheating.
  • Amana Master
  • 9,098 Answers
This could also be a failing high voltage transformer or transformer.
While one should never leave a running microwave unattended, you should especially follow this rule for this microwave until the smell goes away or the unit develops another problem.
If it gets worse, please reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
My ge jvm1653 BD 001 has a burning wire smell
The power supply is overheating and needs to be checked asp, this is a fire hazart and a safety issue.
May 18, 2012 | GE JVM1653 Microwave Oven
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Burning smell microwave
The burning smell is most likely the rectifier burning. Look for a rectanguler black thing connecting from one lead of the capacitor to ground.
Jul 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Making loud buzzing sound & smells like wires burning.
That is the Magnatron or the Hi-Voltage transformer. If I could smell it I could tell the difference. The transformer will produce smoke more so than the Mag.
Eric
Dec 25, 2009 | Microwave Ovens
We brought a Tesco microwave at CULLOMPTON Tesco, Devon last week. It cost £29.00 on its first major use - cooking potatoes for ten minutes - smoke seems to be coming from beneath the machine - it has...
This is almost certainly some of the protective oils and varnishes which were applied during manufacture flashing off.
All new products of this type do this to some degree but your description seems to indicate that it's much worse than normal with your machine.
Ordinarily, you can expect this to cease after a few uses and if the level of smoke and odour you've described is to be expected then the instruction booklet should say so. But as yours has visible smoke and a burning plastic smell I'd recommend that you exercise your rights under the Sale of Goods Act and return it to Tesco for a full refund or replacement. The smell of burnt lubricant is one thing, but a burning plastic smell means you can never trust the oven to be safe: none of the many microwave ovens which I've dealt with have ever smelled of burning plastic unless there was a fault.
You won't find any objection from Tesco as they do have good customer service; and when I lived in Cullompton briefly earlier this year the local branch was even better than usual at keeping customers happy.
I hope that you have found my reply to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 05, 2009 | Microwave Ovens
Microwave smokes and smells like burning plastic
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Amana AMV1162 Microwave Oven Logo
397 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
