Question about KitchenAid KGYS850LT Gas Dryer
Is the pilot light manual or automatic light - KitchenAid KGYS850LT Gas Dryer
  • 1,344 Answers
Automatic
Posted on Jun 05, 2012
If the pilot light goes out will the gas shut off automatically
yes it will, the pilot flame hits a flame sensing device called a thermocouple this device sends a signal to the gas valve and shuts the main valve when therre isnt a flame signal; however, its never a bad idea to manually shut off the gas when youve lost pilot flame.
Jan 30, 2016 | Water Heaters
How to light my heater? I can't fine the pilot.
It appears the pilot is behind the metal thing with two holes on it. Can't tell what the holes are but they look like viewer holes. You can follow the main hose and see where it goes to the control dial. From there you can see a smaller metal line that goes from the dial area to behind the metal thing I'm speaking of. Also there is a skinny brass line which is your temperature sensor which the tip is real close to where the pilot area is. You should be able to push down on the automatic igniter and see a spark. That's where your pilot light is which is a good indicator as well. You may have to hold down the igniter for a minute or two to make sure the pilot does stay lit. When you do find the pilot and the pilot does not stay lit you may have to buy a new thermal coupler. Best of luck to you.
Nov 11, 2012 | Kitchen Ranges
Hi. I have moved into a new home and have a Rinnai Gas Heater Model RHFE 1001FT. When I turn it on the green light comes on and it sounds like its going to start up but after about 30 seconds it turns...
Mela, the problem may be that the thermostat/temperature control is not set high enough, for the heater to sense that there's a need for heat. So, there for, the pilot won't light.
To assist you now and in the future, I have included a link to the Owners Manual for your model heater. You can download and print it for future reference, if you like.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/225.pdf
Hope this helped you the solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
Gas dryer pilot light won't light, stay lit
The pilot light has a thermal sensor above it to determine if the gas is burning or not. If the pilot light goes out, it cools and then the gas line automatically closes so that you don't get a constant stream of gas. When the sensor dies, the same thing happens -- no gas for the pilot.
Replace that sensor.
Mar 05, 2011 | Dryers
Pilot is not lit
There is no pilot light to light up for it ignites automaticly. If it is not working you will need a new replacement spark ignitor
Aug 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you light gas pilot light?
I don't think that there is a constant burning pilot light!! It should be automatic:
There is a ceramic ignitor that heats up red -hot, an electric eye sees the heat and turns on the gas valve ( on my Whirlpool).
Apr 26, 2009 | Dryers
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
KitchenAid KGYS850LT Gas Dryer Logo
85 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
