Question about Sewing Machines
Singer 6268, needle timing advice
I have a Singer Sewing machine, Model #6268. The threads have knotted up on the underside of the material. When I finally was able to pull it all out, it caused the needle to hit on the bobbin plate (hope that is right). Now the needle is bending, not going through. How can I adjust it back as it supposed to be? I have had this happen before, but it cost way too much to get it repaired. And I still don't know why this happens (the threads getting tangled).
Thanks!
Cheri
bootaz2000@yahoo.com
  • nahughes Dec 13, 2008
    singer sewing machine and I have knots on the underside of the material. I know there is a adjust for the timing or tention can you tell me how
Thanks!
Posted on May 29, 2008
The drop in bobbin on my Singer model 600 will jam up when sewing. It will be okay for a short time and than jam up again. It will cause the thread to knot up when sewing w/material. Help
may have to go into an authorized singer repairer for that problem..
might not just be the bobbin but the tension of the cotton winder for the bobbins
or needle pickup issue
Page 1 Instructions for Using Touch & Sewo DELUXE ZIG2ZAG ...
www.singerco.com/uploads/download/1310_600revised.pdfInstructions for Using. Touch & Sewo. DELUXE ZIG2ZAG. Sewing Machine. Model 600 by SINGER. T H E S ' N G E R C O NM P A N Y ...
Oct 11, 2016 | Singer Sewing Machines
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Somethings wrong with the bobbin, it knots up on the back of material
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 15, 2013 | Singer 3116 Simple
My Singer 3116 Simple is tangling up by the bobbin and leaving knots of thread on the underside of material?
Thread it right...with the lever up. Then adjust your top tension.
If you still have problems check the bobbin carrier/shuttle for burrs. If you find burrs carefully sand with fine grit sand paper.
Sep 19, 2012 | Singer 3116 Simple
Thread knots up on bottom of material and won't sew and gets stuck needle will not move up or down
try a new needle & check to see if the thread has come off the thread take up lever,, that will make the machine jam up
Oct 26, 2010 | Singer Sewing Machines
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 5525 sewing machine knots up thread on underside of fabric after three stitches
most commonly this is from incorrect threading top thread. Check manual for threading path or follow threading path usually marked by arrows on machine
Sep 10, 2008 | Singer 8280 Mechanical Sewing Machine
Thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Jun 29, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
522 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
