Question about Insignia NS-DCC5HB09 High Definition Flash Media Camcorder
Green light staying on and when opened it isn't working
    Novelist:
  • 170 Answers
The green light is stating the unit is active and ready to be used.
A couple of tests you can do to narrow down the potential problem is to:
1) rotate the screen (but do not force it) and see if you get the screen to come on.
2) insert a headphone jack into the headphone port and see if the video output wasn't inadvertantly directed to the composite out.
3) connect to a TV using the HDMI connection. You should be able to see the menu screen on the TV and will be able to scroll through the settings to see if there is a switch set to output to another device (although I don't remember that feature for this unit).
4) Check www.insigniaproducts.com for a firmware update and see if that doesn't correct your problem.
If none of these tests yield a correction to your situation, the camcorder is faulty and should be returned or used as a science project.
Hope this helps!
Posted on May 17, 2010
My power cord isn't staying on
some internal wiring has gone wrong go to the apple shop ASAP
Dec 02, 2012 | Apple MacBook Mac Notebook
Own a Heath zenith sh 5105 motion detector flood light. I wired it to plug into an outlet. Flood light comes on when I plug it in and stays on. Seems as if the sensor isn't working. Do I have it wired...
look to see how you have it wired, most sensor lights have many wires to put together, if it is not wired already from factory, you need to look to see how you have it wired, most sensors have three wires one black one red and one white, black wire goes to power, red wire goes to lamp, white goes to neutral, after all is wired you should have only 3 wires a black a white and a green, black to power white to home neutral and green to ground
Oct 31, 2011 | Home
On my Duet Steam washer that I recieved a week ago, none of the cycles or options on the right side of the settings dial lights up green. When I turn it one setting to the right, the light stays on...
this is only a week old, you should call the repair facility or consult your owners manual to be sure that the unit is or isn't doing what it is supposed to do. This should still be under warranty, so the place you purchased the unit from should be able to help you the best.
Joe
Aug 29, 2011 | Washing Machines
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
My door will not go down, I can't make the sensor turn green. It was working good and just stopped all at once. How do I know if I have a bad sensor or it is just out of alighnment?
you have to keep moving the sensors until the light stays on steady green not blinking. one is a sending the other is the receiver. If the lights are on steady green they should show an unbroken line of sight. I have a smiliar problem and have the sensors duct taped together with the green light on constantly and it still won't go down. but firts try and get the green lights to stay on...hope this helps don
Apr 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
My zen stone stays on a solid green light
Just tried this on a zen stone with speaker and worked. Connect your zen stone to your computer. When the green light is on, use a paper clip and press and hold the reset button (small hole on the headphone jack side). The green light should turn off. Wait a bit and it should start blinking to indicate it is now charging. Note: This reset only worked when I had it connected to the computer.
Hope it works for you too.
Ken
Nov 22, 2008 | Creative Labs ZEN Stone MP3 Player
The remote opener reset button goes off and will not work
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
Hope this helps
May 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Insignia NS-DCC5HB09 High Definition Flash Media Camcorder Logo
217 people viewed this question
Top Insignia Video Cameras Experts
Lawrence Oravetz
Are you an Insignia Video Camera Expert? Answer questions, earn points and help others
