Question about Garden
Craftsman Chain saw cuts out
I have a 71-36324 Craftsman chain saw. It has always been very dependable until now. Each time I try to start it it starts fine on a couple of pulls but as soon as I press the throtle it cuts off it sounds like it is choking out.
    Brigadier General:
  • 4,088 Answers
Check the fuel filter for plugging and the condition of all fuel lines. Make sure that all carburetor fasteners are tight. Check the air cleaner and muffler for any plugging. Make sure to warm the engine up before accelerating it. If still not running correctly, try turning the H jet needle about 1/8 turn CCW, which should cause the engine to 4-stroke at speed when NOT cutting, but immediately 2-stroke when you are cutting. Hope this helps!
Posted on May 13, 2010
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
What are the steps to getting the chain saw started and idling? What are next steps to cut tree limbs and oil the chain? This chain saw was given to me without a manual.
If you are a complete novice you should seek some training before attempting to use the machine, as you do not say what model this is we will go through basic starting procedures, fill the fuel tank with fresh fuel mixed with two stroke oil at 25-1, fill the chain oil tank with a non fling chain oil, switch the ignition switch to on, pull the choke fully out, push in the deco valve if fitted, place the machine on the ground, with the tip of the bar away from any obstructions, put your right foot through the back handle to hold the saw down, place your straightened left arm and hand onto the top handle again to hold the machine, now with your right hand crank the engine until it fires once, at this point push the choke fully back in, crank the engine once again until it fires up, flick the trigger to dissengage the part throttle , the machine should now idle.
Be carefull.
Jun 05, 2011 | Poulan Garden
The Chain Came off. I put it back on but it no longer cuts. does th cain need to go on in a certain direction?
It sure does, the chain always turns in a clockwise direction as you look at the saw from the drive side, so the chain on the top of the bar should have the cutting edge facinf away from the saw.
May 08, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Clean the air filter and the spark arrestor and muffler; if the saw cannot exhale it cannot inhale. If no better post back below. Please include the model number.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 18, 2010 | Garden
Craftsman 16 inch cain saw sprocket wont turn
Sounds like the sprocket could be stripped. If so, then you would need to replace the sproket. I suggest you contact Master Parts at 800-466-1446 or online at www.masterparts.net. They may be able to help you.
Jun 09, 2009 | Remington Electric Chain Saw
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Sep 27, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
