Question about Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 - Red has shifted away from blue and green.
Hello. 1st post.
Had the KP-46WT510 since 2003. No problems until now. The red has shifted and can't be corrected with the manual convergance via the remote. When trying to do so, you can move the red crosses up or down, but not left or right. The amount of separation by the red varies across the screen and is worse at the edges while nearly correct at the centerline.
I have the service manual, but I would like to find a troubleshooting manual if anybody knows of one.
I've read some other posts and this points to the convergance ICs or perhaps some of the fusible resistors. Any ideas would be appreciated. There is no bowing or bending of the image in any color. It simply looks like the red has shifted to the right about an inch or so at the edges.
I'm an electrical engineer so I can get and replace some parts, but my TV experience is pretty limited which is why a troubleshooting guide would be nice. I can post images of the screen if anybody thinks that would help in a diagnosis.
Thanks in advance.
Puterbac
  • puterbac Mar 30, 2008
    There are 3.15A 90V fuses on each output of the STK IC's.
    Sony lists them as 1-533-595-31 and I've seen the brand name pico-fuse thrown around which is Littelfuse.
    I can get the part number off the fuse when I open it all up, but I prefer to have everything here before I do that. Digi-key carries most littelfuse parts, but nobody seems to want to tell what actual manufacturer part number of the 1-533-595-31 is as they want you to buy it from them for about 4x the price.
    Thanks,
    Puterbac
    Problem Solver:
  • 17 Answers
first replace the 2 convergence chips they are the big ones with heat sink atached,they start with stk letters and like six numbers,change'em with same ones you can buy'em at www.pacificsemi.com for cheap and original parts,friendly people,ok and that should fix problem,you won't need service manual,or you can get that too at www.asm-service-manual.com for cheap too,ok,let me know how was evething,your friend,faradio.
Posted on Mar 29, 2008
  • FARADIO
    FARADIO Mar 31, 2008
    just replace the STKs and you'll see,that should fix problem.
I have a new smart blue ray player and am trying to set it up using a hdmi cable to my sony KP-46WT510 tv and I have video but no sound?
Two things come to mind. !. are your cables plugged in right? Yellow->yellow, red->red, white->white? 2. Is the sound on the TV itself turned up?
Nov 28, 2013 | Sony KP-46WT510 46" Rear Projection HDTV
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Too much Green
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Aug 31, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony Rear projection TV problem
hi, i had the same problem today. i took a risk and opened the front bottom panel(regular star faced screws located at the side) where the speakers and buttons are located. then i unscrewed the panel located right below it. i then unplugged the wires that were connected to the bulbs(sorry i dont know the technical term for it but there should to be blue,red,and green bulbs). when i reconnected i turned it on it was fine. its been about six hours now and it's working perfect. hope this helps.
Oct 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Our picture is green
This is not a user serviceable problem. Apparently the red and blue screen colour tubes/guns are inactive. Possible open green screen control. Also, if CRT type, the tube may be failing
Apr 14, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Red Green Blue Across The Screen
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm · http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 06, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Greenish picture, or lack of red.
Not tuner........Did you check RGB screen adjust up front
behind access panel?.....Possible CRT issue.............T.
Nov 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
288 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
