Question about Micro Innovations CPQ74CAM Webcam
Need a program
I need to install the program to run my web cam
  • Micro Innova... Master
  • 10,322 Answers
1st You download Webcam Driver. Micro Innovation Cam Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Posted on May 14, 2010
HOW TO USE WEB CAM
normally you need a web cam and a program that uses a web cam. most chat programs like gtalk or skype use them. just sign in attach the web cam and make sure its installed and then allow the program to detect the webcam.
Feb 28, 2011 | Cameras
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
How to install a web cam program back into a
Need start up disk that comes with web cam. Or go to web page specified needed to boot program.
Feb 13, 2010 | ASUS Eee PC 900HD Netbook
I got a ge easy cam maodel no. HO98063, and i don't have the cd to install it. do you have a free installation so i can see my husband . he is in another country
Click on this link. The driver will pop-up on your screen. Download the driver (click save). This is a zip file.
You'll need to unzip it.
To unzip the file, first - right click on your desktop and choose, New' then choose, 'Folder'. Name the folder, Web Cam Drivers.'
Next, right click on the file you just downloaded and click, 'Extract'. (if you have a zip program.) then locate the folder you just created named, 'Web Cam Drivers' and click OK.
The zip files will be extracted to this folder. Next, find the file with the .exe extension (or labeled run) and click on it to install the drivers. (Note: after downloading the drivers, you may need to restart your computer.
After restart, locate the web cam icon: Start > All Programs (then look for your web cam program and click on it.) That should get you going. Just follow the on screen instructions after that.
The files will
unzip it. Then install the driver.
Feb 13, 2010 | GE EasyCam Webcam
DONT HAVE A DISC FOR WEB CAM
to further help you need to know model number of web cam to direct you to right drivers for your cam
Feb 06, 2010 | Creative Labs Creative Webcam
How do I operate the the web cam on my CQ60
Did you have software installed to use the WebCam? You need software to run the WebCam. Install the web cam software in your laptop. Look in your program folder to locate webcam software. Then you access the web cam through this software. You can easily operate it.
Thanks
Aug 13, 2009 | Compaq Presario CQ60-220US PC Laptop
How to use the acer laptop webcam
Did you have software installed to use the WebCam? You need software to run the WebCam. Install the web cam software in your laptop. Look in your program folder to locate webcam software. Then you access the web cam through this software. you also use this web cam in chatting.
thanks
Aug 13, 2009 | Acer Computers & Internet
I need skydude cam driver
Ensure the web cam is secured to your personal computer (PC). Most web cams use a "plug and play" principle. You plug the web cam in; it operates.
Install the required software for the web cam to operate. This may involve placing a CD in one of the drives, or alternatively, downloading the software from a host site.
Always reboot the computer after installing new software.
Click on the desktop icon or the program icon to start the program. If the program is correctly functioning, the web cam will start producing an image of its view on the desktop. Adjust the web cam for a clear picture and the view you want.
Most web programs will have a icon for "take picture." Left click on that icon or button. The web cam, like a normal camera, will then "freeze" that image and place it in a photo library.
Open the photo library and examine the image just taken. Congratulations, you just took a photograph with your web cam.
Jul 10, 2009 | Computers & Internet
Web cam
If the webcame is built in to your laptop you don't need any special program to make it work just need to run the setup cd that came with tha laptop to install the software for the webcam....
Dec 06, 2008 | HP Pavilion dv6000z Notebook
Would like to install webcam
hi
1.) insert the cd that came with the web cam
the auto run will start,
2.) connect the web cam and follow the on screen instructions this will do the work for you,
incase you dont have the cd, sometimes windows has the drivers that it need so you can just connect it, If windows does not have the drivers or you lost the cd
1.) get a program like driver magician
www.drivermagician.com or www.phazeddl.com ( search it there)
3.) install and run the program, this will detect, download and install the drivers for you.
good luck and let me know if you need further help
Jul 12, 2008 | Microsoft Windows Vista Ultimate Edition
Micro Innovations CPQ74CAM Webcam Logo
83 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
