Question about Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator
Problem Hi, I did find the sheets behind the kickplate of my kenmore refrigerator! They are in a language I don't understand since I am not a repairman. I do see the diagrams of the fridge and i'll go in and look for the defrost thermometer and heater clips, but how do i tell if those are the problem? How do I actually test them? Finally, please include the link to the sears parts that you referenced in your earlier email...you mentioned the link but did not include it and when I went to sears.com and typed in the model number for the fridge, it produced no results for a defrost thermometer. thanks
    President:
  • Kenmore Master
  • 2,651 Answers
Sory for del;ay in getting back. ther defrost thermostat(when cold) should show continuity through it, as well should the heater. and as far as the website not showing it, defrost thermostat(not tthermometer).. its located behind the back wall inside freezer section, clipped onto the evaporator
Posted on Apr 02, 2008
On a whirlpool ED5VHGXMB11 how do I manual set the defrost mode ?
http://www.applianceaid.com/adaptive_defrost.html go to this site and it will tell you how to get it into defrost,also remove the bottom kickplate you should find a tech sheet either on the kcickplate or taped to the top of the fridge but it should be somewhere behind the kickplate,it has all the instructions on all tests for your machine,make sure you put it back for future service,without that paper you are screwed
Sep 26, 2011 | Refrigerators
Hi, I have a G.E. 2 door fridge with ice maker mod TFG25PRY,it requires a new compressor. Can you tell me the compressor watts (refrigeration) for this model. Regards John.
Compressors are usually rated in BTU's and are found on the the spec sheet, which is usually under the front of the machine behind the kickplate.
Feb 03, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
I bought a new defrost timer. I can't find my defrost timer switch.
The model you posted ain't a good one. The timer is located inside the command console on a lot of these machines. Right behind the cold control. Another favorite place is behind the icebox on the lower right hand side. You will see the 2 mounting screws and the hold where you can manually advance the timer. Rarely but sometimes under the kickplate also.
Nov 19, 2010 | Kenmore 53642 / 53644 Side by Side...
Need schematic Kenmore bottom freezer model # 79565002401
you can pull off the kickplate(underrthe freezer door, and if you reach up under theright hand side there will be( if no one has removed it) a tech sheet/ wire diagram for you r machine
Mar 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore mod. 59672822200 ice
you should at least have power to ice maker. be sure to check while depressing the light switch assy. some ice amkers are wired through door light switch.after that there should be awire guid. tech sheet under the kickplate to guide you along if needed
Mar 13, 2008 | Refrigerators
Refrigerator is freezing on the produce side
if you get frozen fresh food the air damper is not closing allowing too much freezer air to enter ff section, looks like an electronic controlled wide by side you have, ther should be a tch sheet with a troubleshooting guide behind the kickplate or pasted in an envelope under the front of refrig behind kickplate.
Feb 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kenmore
Check out the drain system. It could be something as simple as a pinched drain hose or a cloged pump.The trouble shooting sheet is behind the kickplate or under the top. This will walk you through the proublem.
Dec 07, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator Logo
93 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
