Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet and its flashing f2 - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
F2 PROBLEM
in google search bar ,type (whirlpool ghw 9400 duet fault codes),
then clic on (whirlpool duet intro)
(https//secured whirlpool.co.service) this should give you a good description of the machine
Jul 30, 2011 | Whirlpool GHW9400 Duet Washer
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It keeps F2 me or saying suds I can't remember
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Jan 03, 2010 | Whirlpool Washing Machines
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet that flashes f2 and will not do anything, it freezes up and locks up
F2 is an indication of long drain, id try to remove hte lower access panel (3) screws across the bottom front of unit, youll see a filter clean out ( large off-white turnscrew) unscrew snd remove debris from area. be warned there will be water inside hte filter when unscrewed, so UNPLUG UNIT FIRST!!!!!!!!!! and grab some towels first
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer need to be repaired
The f2 code is a pump problem. Need to look in pump. It is the first cycle to be satisfied when started.
Oct 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
