I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use to play the 3 3/4 ips on the Teac 3340?
    Problem Solver:
  • 9 Answers
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
Posted on Jun 08, 2010
  • Audio Player... Master
  • 1,267 Answers
There is no adapter to play tapes slower on this unit. There are other Teac models like the A330S or A2300S that can do it. You need to match up your tapes to the proper machine.
On another note some people record the high speed audio into their computer and then use software to cut the speed in half- that should work as well. A lot of trouble though.
Posted on Sep 12, 2012
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have a TEAC 3340 reel to reel recorder and
No, that would require slowing the capstan or making its diameter smaller for the rpms it turns now. Sorry.
Posted on Mar 18, 2010
Testimonial: "Speedy response with the exact information I was looking for. Thanks for the help"
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
Reel recorder
The A4070G can record in each direction but has a switch that needs to change to switch the heads. This must be stuck after all this time and so the deck needs service. They are not easy unit to work on. I have one in my shop now. The bad news is that they use combo record and erase Ferrite heads that can not be sourced anymore.
I am very familiar with this model as I worked at Teac and fixed many of them.
Apr 20, 2014 | Teac Audio Players & Recorders
How do I connect a teac ax-20 mixdown panel to a teac a-3340s reel to reel?
It's a 4-in, 2-out panel. Well, you attach up to 4 INPUT channels (labeled plainly on it) and run the two output channels to any two of the the Record In connectors on the Tape Deck.
Sep 11, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
I have teac reel to real tape recorder. It drags in play mode and the speed is wrong. Do I need to change the belt?
Hi....
Most likely .
All the belts should be changed out and wheels/rubber rollers need cleaning.
studiosoundelectronics.com
or
prbline.com
Jan 05, 2009 | Teac DRH300DAB Receiver
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Reel to reel tape
did a lot of surfing,and found a number in yellow pages,made some calls.and found a supplier thankssssss. vasili..
Mar 28, 2008 | Teac Audio Players & Recorders
Teac X-10 connections to a dbx 224
connect the x10 outputs to the dbx 224 line in connect the dbx 224 outputs to the cd recorder anlog line in windman
Jan 29, 2006 | Pioneer PD-R509 CD Recorder
406 people viewed this question
 Grubhead
Grubhead
