Question about Microwave Ovens
Lg solardom closed door after use fuse box tripped not working
Lg solardom microwave convection combi - closed door after use. Fuse box tripped out and now no power to unit. Fuse in plug okay. Is problem likely to be fuse in unit and if so where is it?
MicrowaveSvc
  • 9047 Answers
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I would like to know
If your owner's manual doesn't cover lamp replacement, you will have to take the oven apart to do it.
If you don't have your manual, you should be able to download it from here.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's here.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Otherwise, please reply back with your model number so we can help you.
Posted on Jul 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: LG Convection Microwave Oven MC-7843D
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
In some brands there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Jul 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: My microwave over my stove
We have the service manual for this model and have uploaded it to our site here to help you.
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Whenchecking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
ForGoldstar / LG / L.G. parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
My lg ms3949cs microwave tripping the breaker when I press start button but was working before.Please help
More than likely the klystron tube is defective, that draws a lot of current. Best path here is a new MW
Oct 18, 2016 | LG Microwave Ovens
Replace door on lg solardom microwave
You need to be carefull. You need a tester to use to check aroud the door after installing door. You should have a qualified tech. check it.
Jul 09, 2016 | LG Microwave Ovens
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
My LG Microwave LMV2015st is blowing fuse,Why?
possibly the diode is shorting. replace the diode before replacing the fuse
Mar 17, 2014 | LG Microwave Ovens
My LG LMVM2055 just stopped working. i have checked the fuse box and everything is fine. i unplugged the microwave and plugged it into a working outlet and it still does not work. is there an internal...
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
Jan 09, 2011 | LG LMVM2055 Convection/Microwave Oven
No lights no tripped breaker no power
There is a fuse inside of oven, do not attempt to replace it as there are high voltages remaining for a period, danger of shock. The cabinet has to come off, and you need to know what you are electrically capable of. thank you. probably fuse.
Nov 02, 2010 | LG LMV1630 Convection/Microwave Oven
Blown fuse
Check your door switches or your turntable motor, these could also cause the fuse box to trip.
Mar 25, 2009 | Sharp Microwave Ovens
Micro blow circuit
You have a faulty interlock switch. This is one of two or three switches in every microwave that are operated by the door. The interlock switch is wired to blow the fuse if you try to run the oven with the door open. The switch may have gotten knocked out of adjustment (say by slamming the oven door) or its contacts stuck closed. If there are no other problems with the oven, a new switch should clear this up.
Mar 24, 2009 | LG LMV1630 Convection/Microwave Oven
Fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
Aug 03, 2008 | LG LMVM1935 Convection/Microwave Oven
My microwave over my stove just stop working. There is power in the wall receptacle, the circuit breaker has not tripped,what is the problem.The microwave is a LG appliance model#LMV1630ST, serial...
Jul 15, 2008 | Microwave Ovens
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
