Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
SHARP AQUOS 32 INCH FLAT SCREEN
THIER IS A LETTER K ON THE SCREEN THAT WONT COME OFF. AND ALSO THE VOLUME ONLY WORK AT LOWEST, MIDWAY AND LOUDEST NO IN BETWEEN
  • 1 more comment
  • Anonymous Jun 13, 2008
    Can you please provide me more information about this. By it doesnt work
  • JAVW Mar 16, 2009
    A GREEN LETTER K APPEARS ON THE LEFT SIDE OF SCREEN.
    WHEN I PERFORMED THE SUGGESTED TIP, THE GREEN K TURNED INTO A BLUE K....AGHHH
  • Laurie
    Laurie Jul 17, 2014
    i cant program my remote it says operation unable to load
I had this problem as well guys. Just found a fix thought i'd share.
I simply went into menu>setup>reset . This will perform a factory reset, and you shouldn't have that K or the volume problem anymore.
I tried all the fixes involving volume- input- nothing worked. I tried volume- ch- but that K never changed colours.
It all came down to a simple menu option reset.
Posted on Aug 21, 2009
  • 372 Answers
Hi.
Easy fix do the following.
Set is in factory mode. To remove follow these steps below extracted from the service manual.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. The letter K should have disappeared from the screen.
http://dysonmanuals.llc.nu/
Posted on Mar 30, 2008
  • bridget_95 Oct 08, 2010
    i tried everthing and this worked thankyou
  • Cuz Calvin Oct 16, 2012
    Thanks a lot for your solve on this problem. I have tried your advice and succeed. Thank you. May God bless you.
Can you provide me more information about this... By me it doesnt diseppeared..
thx
Posted on Jun 13, 2008
SOURCE:
Sharp lcd tv 32 400m. pc input problem, can't fungtions input 5 (blur)
i connect tv cable but vedio is not working only audio is working in top K letter it is showing in screen
plz send solution
chakradhar
9440176800
india
Feb 01, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My sharp aquous tv has white lines running vertically like a pin-striped suit.
my 32 inch sharp Aquos has white lines running in the background of the screen
Jan 28, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos 32' LCD has a heavy green tint to it. I tried reseting the settings back to factory settings, but it didn't help.
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Aug 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Re: K displayed and Volume control
Hi.
Do this it will remove your set from factory mode.
  1. Unplug the AC power cord of TV set .
  3. The letter K should have disappeared from the screen.
Your set will now work correctly.
May 25, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
2,946 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
