On channel 25 on
On channel 25 on my doughters tv the sap mod I done't have a remote, is there another way to take the sap mod of that channel without a remote.
    Problem Solver:
  • 17 Answers
try using menu button from tv go to audio menu and see if you can find sap option,if not try buying an universal remote,program it to work with tv and pull the menu, that should fix problem,thanks,faradio.
Posted on Mar 29, 2008
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
Turn off stereo sap in tv
buy an rca universal remore for 8.00
Oct 14, 2013 | LG Televison & Video
How do I turn off the SAP? My mom somehow turned it on and now only gets sound on some of her channels and some in spanish!
U have the original tv remote?Yes.Look for it on the remote for a button that said SAP pushes to turn it off.If u don't have the tv original remote,might could also be turn it off inside the tv internal Menu functions setup,but probally not because the SAP design in tvs are mostly just a SAP button on the tvs original remote design only.Try website like to buy the tv original remote.
May 10, 2011 | Sanyo DS32224 TV
Some of my channels are in sap and I don't have an audio option on my menu nor the orignal tv remote. How do I change it?
Sorry the SAP function are only can be change in the Audio option menu or the tv original remote only that have the SAP button.Try website like to buy the tv original remote.
Apr 19, 2011 | iLO IWT3206 TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
I do not have cable or satilite. I have problems with some programs on cbs being broadcasted in Spanish, while my other tv is in English (also not on cable or satilite) Why is tis happening?
The problem you are having is that you have SAP turned on. When SAP is turned on you might have one or two channels that come in in Spanish, French or no audio at all. The feature is called MTS and you should have either an audio or MTS button on the remote control. If not there should be an audio section in the menus and you should be able to turn SAP off from there. You want the audio on your television or cable box/satellite receiver to be on Stereo or Mono all the time not SAP.
Sep 11, 2010 | Emerson TS2587D 25" TV
I have no volume on channels 2 and 7. All other
Your SAP audio function is on. Look on your remote or in the TV menu for SAP or MTS. There are 3 settings, Mono, Stereo, and SAP... set it to Stereo. I hope this was helpful, best wishes.
Mar 28, 2010 | Toshiba 32A33 32" TV
Use your remote control to check the TV SAP settings. This is "second audio program" and is often used to carry the TV sound in another language. If SAP is turned on you won't notice it unless you tune to a channel where the SAP signal is present. Most remotes have a single button to control the audio settings, so it's easy to turn the feature on without knowing it by bumping the button. Turn off SAP and you should be back to English.
Mar 06, 2010 | Televison & Video
TV in SAP mode and cannot remove. Lost original remote.
I had the same problem. You have to order a replacement remote with the MTS button (Multi Channel Sound)
Call RCA Support @ 1.800.338.0376 I believe the remote part number is RCR130TB1
Dec 22, 2008 | RCA 257003 Remote Control
No sound on two local channels?
Do you have the original remote? it will look like the one here: If you do not have the original remote you will not be able to switch off the SAP setting, without it as there is a button that controls the sound. when this button is pressed you see where to turn off the SAP setting. Good Luck
Apr 06, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
