Question about Motorola Mobility RAZR V3
Battery charge only lasting a couple of hours
Original battery that I have had almost a year was saying "invalid battery". I got a replacement battery and the life now only lasts a couple of hours.
  • Motorola Mob... Master
  • 641 Answers
There are little differences in the battery,they are all BR50 battery's.but some have a notch with another contact on the top side and some don't.I have found that the battery's with out the notch do not work properly in all V3's.You could also try a different charger,maybe your charger is getting weak.
Posted on May 13, 2010
Battery fully charged, bike turned on after, but on 2nd try after couple of hours, no power
Based on what you've said here I would say that either the battery is incapable of maintaining a charge or something is draining the battery. To test to see if something is draining it, disconnect the positive cable and put an ameter between the cable and the battery to see what current is being 'used' when the ignition switch is off. It should read ZERO amps. If there is current flowing then something is draining the battery - pull fuses to find the culprit. If the drain shows ZERO amps then it's possible the battery is tired and needs to be replaced. Motorcycle batteries don't usually last more than a few years.
I hope this helped. Sorry for any typos.
Scott
Nov 15, 2011 | Motorcycles
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My new samsung galaxy ace has a VERY short battery life.. it doesnt matter if i change the settings.. it only last for about 1 day at most.. not even 24 hours.. how can i fix this?
"If your battery sat on the shelf for a year, then it has deterioated enough to where it would only hold 1/ 2 to 2/ 3 the original charge."
galaxy ace is relatively new. nothing you say makes sense.
if you don't use data service, you can switch to gsm (not 3g) to preserve battery life. works with me across devices.
Feb 24, 2011 | Samsung Cell Phones
I have a pride go chair that is only one year old. I USE IT INSIDE MY HOUSE ONLY A COUPLE OF TIMES A DAY AND CHARGE THE BATTERIES EVERY NIGHT. The off board charger has already been replaced once under...
The small batteries (17 Amp hour I believe) are notorious for lasting a year and often much less. I consistently replace the original OEM batteries supplied with this chair at the 6 month point. The manufacturer warrants these sealed gel lead acid batteries for only 6 months. Try the AGM (advanced glass mat ) batteries and you should get better life out of them. They might be more expensive at retail pricing but your insurance should pay for the better batteries in my experience. Make sure the charger replaced under warranty is the correct amperage for these small batteries otherwise the output could burn the battery plates.
Aug 16, 2010 | Pride Go Chair Travel Power Chair
Hace a APC XS 900 that said battery needs replacement, unit is about a year old. I replaced the batteries & it lasted about 2 hours & again says replace batteries. I know the new batteries are OK...
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Mar 13, 2010 | APC Back-UPS XS900 (BX900) UPS System
Motorola razr2 v9
it sounds like a one in a million defective battery goto service phone tech show them your receipt and have them replace this battery
May 28, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Invalid Battery
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
May 14, 2008 | Motorola Mobility RAZR V3
Not charging
Did you try charging the batteries with another charger?
Mar 03, 2008 | Sennheiser RS 130 Consumer Headphones
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
