Question about Xante Accel-a-Writer Laser Printer
I need a new toner cartridge for my Accel-a-Writer3 G. Where do I find one and how much does it cost
Try superwarehouse.com
or Xante in Mobile, AL (xante.com)
or some of the paper suppliers that supply commercial and local printers might also carry the toner.
Posted on Jul 21, 2010
2 Suggested Answers
  • 1768 Answers
SOURCE: I need a new toner cartridge for my
You can probably go to the Hewlet Packard site or to Office Max or Office Depot the price varies between 113.00 to 150.00
this is depending on a refilled cartridge or a new one, This will also depend on the model and it use.
Posted on Mar 18, 2010
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly
I hope this was helpful
Mar 17, 2015 | Brother MFC-8860DN Printer
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Sir i have toshiba e studio 212 machine when i on her empty toner replace toner appear the msg on screen what is the solution
Need to go to an office products company and purchase a toner cartridge. You might be able to have your toner cartridge refilled for half the cost of a new cartridge $80.
Aug 17, 2013 | Toshiba e-STUDIO207 Printer
How to refill toner in canon lbp2900 printer
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
May 29, 2011 | Canon LASER SHOT LBP-2900 Printer
I have cannon printer model L11121E, lately ,its not printing well, some of the matter comes up very light,unable to read, as if the catridge is running out, this is supposed to be laser printer, what...
The toner may be low or nearly run out. Remove the toner cartridge and give it a shake in a horizontal position, then replace the toner cartridge in the printer. This may give you a few more prints.
If not you need to replace the toner cartridge with a new Canon toner cartridge, or purchase a re-manufactured toner cartridge for your model laser printer. These re-manufactured laser cartridges are approx. half the cost of a new toner cartridge.
Feb 08, 2011 | Office Equipment & Supplies
Dear Sir, We have canon xerox machine and our deler ask high cost for spares Ex. OPC - 6000, Tonar - 2350 also he told if you fefile your tonar it damege your machine due to this magnetic rod ,OPC can...
Please let me know the model of your machine. In general, if you are having print quality issues, such as lines dots or black patches, these are usually due to toner cartridge. Genuine Replacement of Toner cartridge is advisable.
However, you may get your toner cartridge re-filled, if its parts are working properly. Cartridge parts like OPC, PCR and magnetic roller can be replaced. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine.
Hope it helps. Let me know if any clarifications are required!
CreativeTECH
Nov 10, 2010 | Xerox Office Equipment & Supplies
Need toner cartridges
depend upon your locality
hp can deliver toner cartridges at your doorstep
to contact hp
pls go to "www.HP.com/in " then click "hp- order-a -cartridge" site
Aug 12, 2010 | HP LaserJet P3005d Printer
Mar 18, 2010 | Xante Accel-a-Writer Laser Printer
HOW TO REPLACE THE DRUM?
Laser printers usually have toner cartridges that include the drum.
You can purchase new Canon toner cartridges or recharged cartridges, these are approx. half the cost of a new one.
Nov 27, 2009 | Canon imageRUNNER 1330 Laser Printer
Xante Accel-a-Writer Laser Printer Logo
112 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
