Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Internet service on only 1 pc
I am tryin to hook up 2 pc's- I have them both hooked up to a router- but only the knew 1 has internet service - do I need to get a cap 5 cable?
    President:
  • 1,851 Answers
If the unconected pc has not something like WiFi (or wireless internet), the only way is to connect it with an ethernet (cat 5 as you mentioned) cable. If the cable is a problem, there is the posibility of wireless connection but you need extra hardware (not very expensive but the cable is cheaper for sure)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 13, 2010
Is there a way i can hook up internet to 2 desktops with 1 modem/router?
That is exactly what a router is for.
If your modem doesn't have multiple ethernet connections, then go out and buy a generic router (like linksys or belkin or cicso or netgear, etc.) and hook the WAN port of the router to the modem's ethernet connection, and then hook the computers into the multiple ethernet connections on the router.
Aug 24, 2011 | Computers & Internet
I just put a pc in my room and got a wireless router because i have a pc in my living room already hooked up to the internet. i tried to hook up the wireless router and get a connect but now the my pc...
try to check the the network cable.there is something wrong in your cable.maybe wrong setting of wires.but you said you got wireless router right.why go on wireless..much better you buy a wireless USB connector.less maintenance.if you prepared wired..this is the setting of pins of network cable.8 pins each RJ45 both ends. 1.stripe orange 2.orange
3.stripe green 4.blue 5.stripe blue 6.green 7.stripe brown 8.brown
Jul 15, 2011 | Computers & Internet
How to hook up to new computer
1.You should have a modem you received from your ISP (Internet Service Provider).
2.Plug the Ethernet Cord Into the Internet port of your router.
3.If you have a desktop computer plug in the ethernet cord into one of 4 ports of the router.
4.Open you wireless connections and connect to the internet.
Mar 20, 2011 | Belkin Basic Wireless Router
How to hook wired router to cable box. What is WAN outlet
all of your computers should get hooked up in ports 1-4 and the WAN port should be hooked up to your broad band router from your internet service provider. so if your first computer is hooked up to port 1 just plug your second into port 2 and every thing will work fine.
I hope this helped.
Thank you,
Norse
May 18, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
Yes, the 2nd PC will need an RJ 45 cable ( straight through ) not a crossover.
This cable is connected to the port connector in the router on the back numbered 1-2-3-4. That is if it is a 4 port router.
You can select either one preferably the number 2 port will do.
Then the PC should detect the connections and you will be on. automatically.
1. Check the network in the task bar on the bottom right of you screen for the 2nd PC and see if you have a connection.
If this is Windows XP you will see an Icon with to monitors showing . Right click to see the connectivity.
Mar 18, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My pc has room for one ethernet cable and its already taken to a router box. i have no idea what its for but now there seems to be nowhere to hook up my 360. i want to hook up for xbox live and netflix....
Simply put
You need to plug your xBox 360 into the Router not the PC.
The Router should have more than one ethernet slot. (That is what is generally meant by the term Router).
Therefore:
1. Plug one end of the Ethernet cable into your xBox 360.
2. Plug the other end of the Ethernet cable into an available slot on the Router.
If your Router is constantly connected to the Internet then this should solve the problem. If it is not, then connect to the Internet via your PC and then when the internet is on the xBox should find it.
Hope this helps. Regards,
Feb 09, 2010 | Microsoft Video Game Consoles & Games
Wireless access using the dell true mobile 1300 pc
2 things...
1. test your internet connection by plugging back into the router bypassing the router.....
2. Have you set up the router?
Jan 14, 2010 | Dell Inspiron 1000 Notebook
Hook up router and can't access internet from wired computer.
Sometimes the modem-computer-router not "sync" together.
Try this.
1-hook the computer to modem. Internet yes? good.
2-hook the computer to router and check you IP. If it like 192.168.1.2,
the router's DHCP is working.
3-reset router to default setting.
turn off all and turn on modem, router, computer.
keep me posted.
Jul 06, 2009 | Belkin (F5D7231-4) Wireless Router
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
ATT/SBC gateway router....
Take the ethernet cable from modem to PC and hook it into the router(modem to router)...run another ethernet cable from the router back to that PC(router to PC). All you machines should be fine then.
Jan 25, 2009 | 2wire 2700HG-B Router (2700HGB)
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
