Question about Peg Perego John Deere Gator HPX Ride on Toy
How do you move the seat back - Peg Perego John Deere Gator HPX Ride on Toy
    Genius:
  • Peg Perego Master
  • 1,474 Answers
You have to flip the gator on its side then you will see four red knobs underneath loosen those and then move the seat to the desired position then tighten the knobs
Posted on Jun 14, 2012
Power seat
Most Fordicon1.png products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works besticon1.png to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
Oct 21, 2013 | 1998 Ford Expedition
Driver's side power seat won't move back but will move forward, up and down
If this is a 1994+ Ford, it might be that the seat belt latch is the problem. Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
Sep 09, 2013 | Computers & Internet
I have a 2005 mercury montaineer. The drivers seat which is a power seat, will not go back all the way. It makes it half way and then nothing. Please help!!!
Aug 28, 2013 | Cars & Trucks
Electric seat won't go forward or back. Sounds like it's trying
Aug 22, 2013 | 2003 Ford Expedition
Power seat control not working to move seat back. works to move seat forward and the other power controls work for seat back postion and such. how can i manually move the seat back. once it is back it can...
that is easy find the motor under the seat that moves the seat back and forth take and neg wire and a hot wire carefully touch the twoo prongs going to the motor after diconnecting the plug going into the motor. it sould go forward one way and croos the wires to get it to go the other way if this works get a new switch and have a working seat.
Jul 01, 2010 | 2002 Chevrolet TrailBlazer
Front driver seat only moves apx. 2" back from the front of the track. Fuses are good. Back of seat controls work. The pre sets do not move the seat back.
Make sure there is nothing obstructing the seat from under the seat track.Sometimes things fall down there and will jam the seat track.Move the seat up all the way and look it over real good under the seat.Hope this helps.
Dec 21, 2009 | 2003 GMC Yukon XL
1998 corvette drivers seat up/down no forward/back
Try removing your seat bottom to access small motor that moves the seat,Tap on seat motors while holding seat switch in the forward position.
Aug 25, 2009 | 1999 Chevrolet Corvette
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Jun 02, 2009 | 2004 GMC Envoy
Driver's power seat not working properly on 2004 tahoe
it sound like you need to replace seat control switch
May 14, 2009 | 2004 Chevrolet Tahoe
Forward and back movement is only 2 inches
sounds like youve got a kiddy toy stuck in the rail ,4 bolts and the seats out !! BE CARFUL of the spring loaded slider ( if it is spring loaded ) it will *** you if given the chance.
Jan 17, 2009 | 1998 Ford Explorer
Peg Perego John Deere Gator HPX Ride on Toy Logo
69 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
