Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frig and Freezer not working.
Last night my both sides where not staying cold. I could hear a fan running but no compressor sounds. I removed all the contents and shut the frig off for the night with the doors open. When i restarted it today around 6:00am i heard both the fan and compressor on. By 11:00am it was back to just the fans and the inside temp in the freezer never went lower then 45.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Posted on May 02, 2008
SOURCE:
8/28/14 my frig is not cold but my freezer is
Do u hear fan running in freezer? It only runs when compressor runs! Sounds like your problem:) check it out....
Aug 29, 2014 | Kenmore 53642 / 53644 Side by Side...
How to check fan motor funtionality of PFCS1NJXB SS?
It probably has two fan motors. One that keeps the compressor cool and one in the freezer compartment that blows cold air out into the freezer and into the frig. You should be able to hear the motor running and feel the air coming out the vents when you open the door of the freezer. The fan runs all the time. If you do not feel or hear, the fan is not working. The one on the compressor, take the cover off the back and you can see if the fan is turning. It runs all the time also.
May 06, 2014 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Kenmore side by side....freezer is not staying cold enough to keep ice cream frozen, middle wall between frig and freezer is extremely hot.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 01, 2011 | Kenmore Side by Side Refrigerator
Model MSD2756GEQ Maytag plus side is no longer cooling, the freezer is starting to defrost from the top, but bottom portion of the freezer seems to be still cold. the fan of some sort is still working, no...
Refrigerator
heatman101
Jan 29, 2011 | Maytag MSD2758G Side by Side Refrigerator
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
158 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
