Question about Avaya 700340193 Corded Phone
How to I change the time on the clock in the little box?
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Posted on May 14, 2010
Do you have an instruction sheet? How do I change the time?
open the little door at the back, you'll see a black box, in the bottom beside the battery is a tiny wheel, turn it to adjust time
Mar 10, 2015 | Home
Lenovo laptop z560
Your computer's clock is used to record the time whenever you create or modify files on your computer. You can change the clock's time and time zone.
  1. Open Date and Time by clicking the Start button, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
  2. Click the Date and Timetab, and then click Change date and time. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the Date and Time Settings dialog box, do one or more of the following:
    • To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
    • To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
    • To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
  4. When you have finished changing the time settings, click OK.
  5. To change the time zone, click Change time zone.
  6. In the Time Zone Settings dialog box, click your current time zone in the list, and then click OK.
    Note
    • If your time zone observes daylight saving time and you want your computer's clock to be adjusted automatically when daylight saving time changes, make sure the Automatically adjust clock for Daylight Saving Timecheck box is selected.
  7. Click OK.
Sep 25, 2013 | Computers & Internet
Clock did not change to dst. How do I change clock?
You don't say what operating system you are using but you need to get into the control panel (Windows) . On there you will find an option for date time settings and you can change it quite easily. On the time zone you will find a little box that says 'change for dst' make sure this is ticked to solve future problems.
If you computer is continually losing time it could be the CMOS battery is running low and needs to be replaced.
Mar 13, 2011 | Computers & Internet
Just installed the new t-104 and the clock runs slow
The clocks on Intermatic timer run on-time for years.
If this a new timer >> then buy another one, and swap out the insides without changing the box, and return the bad one.
Voltage variation will not affect clock speed. The only electrical thing that affects speed would be the cycles. Your household has 60 cycles. The clock motor is 60 cycles.
When you connected wires, the wires fit under a metal clamp and the screw pushes the metal clamp down against the wire > only copper wire should be under that clamp > if some insulation is also under the clamp, then the contact might not be 100% all the time, which would stop the clock. Check that all your wire are down tight.
If wires stop in a junction box before arriving from breaker box, there might be a loose connection in that box. Trace back your line, especially if this is a pool control with a junction box.
A shorting breaker can stop voltage from time to time, making it appear as if the clock is slow. If one leg of the 240V stops, the circuit stops. You can check breaker for loose screws. Does breaker feel warm? Is there a crackling sound when you jiggle breaker. You can put your timer 240 lines on similar sized 240 breaker and see if clock runs slow ... that would indicate whether the problem is clock or breaker.
If timer is old, the plastic clock gears can get worn. The metal timer gears rust or clogged with dirt. Snap out the insides and inspect for rust and dirt. Use a little WD-40. Turn off power since WD is extremely flammable.
Snap the manual override back and forth. Does it snap crisp? Or is it sluggish? The clock motor turns the dial until the tripper encounters a metal lever. The Clock keeps pushing the tripper until the tripper clicks the metal lever >>> which happens to be the same lever the manual override is connected to.
So if the manual override is very hard to push ... ... a sluggish manual override might slow the clock. You might put some grease on the lever where the trippers touch.
Finally, the clock motor can go bad.
$16, Grainger sells 240V T100 series clock motor
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
Oct 09, 2010 | Intermatic T104 24h 208-277v Mechanical...
Stromberg Time in a Box Professional Edition Full Version for PC: My Stromberg time clock is stating "memory is full...
I have run across a great little place in pittsburgh that has software upgrades for time clocks....go to www.shop.gatewaytime.com good luck:)
May 16, 2010 | Caere Stromberg Time in a Box Professional...
How to set the current time.time did not change when we turn the clock back one hour.
either your 1440 was never set to include daylight saving time or the unit was reset at some point.
the time is automatically set once you choose your time zone and if you observe daylight saving time, you must check that box..
go to the main menu, then system option and click on the time zone tab, then select your time zone and check off the little box for daylight saving time.
bill
Nov 06, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Jan 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Avaya 700340193 Corded Phone Logo
123 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
