Question about GE DPSR483EA Electric Dryer
Ge DPSR483EA Electric Dryer was making a scraping sound when operating now a felt like belt has come out on the inside of the dryer. What do i do? Kris Long
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerGE DPSR483EA Electric Dryer was making a scraping - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
2 Suggested Answers
  • 767 Answers
SOURCE: GE DPSR483EA Electric Dryer was making a scraping
The problem is something got between the drum and the felt seal between the drum and the front of the machine. You will have to pull the front off and find out what caused the felt to come out and then put the felt back in place and put the front back on.
Posted on Mar 18, 2010
Where to I connect the 4th lead (green) from a 4-wire cord to a DPSR483EA GE Profile dryer?
oldtech2332_102.jpgThe green ground wire goes where the linkage from the center terminal on the terminal block is...removed that linkage from the white wire center terminal on the code block and install the green wire to where the linkage connected to the cabinet
Sep 11, 2011 | GE DPSR483EA Electric Dryer
Squeling on dryer model #dpsr475ewoww
replace the belt and tensioner pully to eliminate the squealing
Sears sell these parts in sets
Jun 07, 2010 | GE DPSR483EA Electric Dryer
GE DPSR483EA Electric Dryer was making a scraping sound when operating, now a felt like belt has come out on the inside of the dryer. what do i do? Kris Long
Mar 18, 2010 | GE DPSR483EA Electric Dryer
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
My dryer is blowing cold air.
well if it was the door switch or heater box fuse nothing would work,i'am almost sure it's the heating coil that's broke,it is a $39 part online ,it's pretty easy to do,let me know if if you want to give it a shot,before ordering we'll check to make sure that's it-mike
Nov 02, 2008 | GE DPSR483EA Electric Dryer
GE DPSR483EA Electric Dryer Logo
227 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
