Question about Ovens
1950's philco stove model # UD439.
1950's philcostove model # UD439. Right hand handle to open the stove has a little clip the you screw from the handle into the door!!! Ours broke off. It's about 1/2 inch with a screw hole in the center.
aborcass
  • 2651 Answers
SOURCE: handle on oven door has come off
the door willneed to be dismantled in order to resecure t he handle, dont knowexactly which model you have , but youl need to rmov eth door from the unit, andthen with it layin on the table or other flat surfaceyoull nned to remove the screws holdiongthe lower glass panle on, and form there just a matte of removing the screws allowingyou to get top trim off the no yo can tightern handle an reassemble
Posted on Mar 08, 2009
  • 384 Answers
SOURCE: GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Posted on Apr 02, 2009
  • 25 Answers
SOURCE: Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Posted on Apr 07, 2010
  • 10865 Answers
SOURCE: I have a ct227 and I need a door handle. The elbow
Hello. If the screw hole is stripped, you can repair that by using some one minute epoxy and a wooden match stick to make the hole smaller. Just work quickly in this sequence:
1. force some epoxy into the hole.
2. put epoxy on the match stick and push it into the hole.
3. Break off the match stick so it is not too long
4. Align everything and drive the screw in to the repaired hole.
5. let it set up for a few minutes before using it. J.
Posted on Jul 05, 2010
BElectric
  • 1140 Answers
SOURCE: After implementing the self cleaning
Hi - Welcome to FixYa.
Many ovens, including Maytag, have a built in safety feature which prevents opening of the oven door for about 1 hour after the self-cleaning cycle has finished. The self-clean feature works at a much higher temperature than the maximum cooking temperatures so it's designed to prevent access until the oven is fully cooled.
If you have already waited an hour and still can't open it, try leaving it a little longer. If it still doesn't open or you've already been waiting at least an hour, please post back for further assistance.
Hope this helps.
Regards,
BElectric
Posted on Nov 21, 2010
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
Open door handle is loose on a true temp GE stove how do I tighten the handle
You will need to unscrew and unfasten the inside door panel to access the screws that need to be tightened.
Jan 06, 2013 | Ovens
Owners manual for 1950 o'keefe & merritt stove
Sorry, I only have information on the STOVES 720ef and thus unable to help.
Nov 14, 2011 | Stoves Ovens
How do In open the top of my stove to replace one the elements # 316224300. For range Model #: 790.95889302? thanks
On the bottom of the cooktop is a couple screws that hold it down...open the oven door and look up to the bottom of the stove top and you will see those screws
GENE
Aug 27, 2011 | Kenmore Ovens
I would like to know how to adjust the stove so that it sits level ?
Most stoves of this type have both wheels and screw adjusted levellers (generally in the front only).
The lower drawer opens to reveal these in the corners or a loose clip-on front panel needs to be removed by gentle pulling. The knurled wheel like knobs are generally turned anti-clockwise (Right to Left as you face the stove) to screw out and thereby lift the stove front up to suit your requirements. Good Luck.
Sep 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hello we have a fisher and paykel classic stove and top with four elements model no RA610MAW as we are in the bush we need to know how to change the seal in the oven which the door closes on we have the...
c55aadb.jpg Isolate power from device, remove screws to free back panel.
769e143.jpg Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
e87a68d.jpg Remove screw on front central upper clip.
42f6dbf.jpg From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
e8ea79b.jpg Remove the old perished seal.
f86ae37.jpg The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
Mar 19, 2010 | Fisher Ovens
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Oven cleaning
1) take oven door off (position door fully open, flip forward the 2 jammer levers on the hinges, raise door 1/2 open until hinge springs are relieved by jammers, gently ease out door)
2) at the bottom of the door there are 3 screws on left and 3 on right. Remove the innermost screw on left and innermost on right.
3) ease open the glass front by pivoting on the top of the door, separating the bottom that you have just released by removing the 2 screws.
Written by a Chartered Accountant who has current first hand experience of the FEA0614 door
Apr 11, 2009 | Jenn-Air JJW8230D Electric Double Oven
Handle on oven door has come off and I need to know how to get at the screw to tighten it back on.The handle is attached to the same piece that has the vent holes in it. I don't see any screws at all to...
Mar 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How to replace the solid element on a ge modelJ37SVWX electric range
removing burned out solid element on heartland stove and replacing with new one..It is enclosed with a chrome ring on stove top
Nov 14, 2007 | Ovens
Ovens Logo
228 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
