Question about Samsung PCL5415RB 54" Rear Projection Television
Double Image Our Samsung projection Tv has a double image. The bottom of the screen image comes across and repeats the image around the middle of the screenin a rainbow like shape. The repeated image is orange red in color.
  • 71 Answers
SOURCE: tv double image
It's not only adjustment, you have to replace both STK 392-560 IC.
Posted on Dec 06, 2007
rockitman187
  • 2559 Answers
SOURCE: I have a sony projection
When you first turn it on,Count the flashes on the standby/power button.
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground,or held high), IK video path is defective.
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This isalso a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on
the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback
transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times
you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors
are bad, check R8051 and IC8005, also on the "D" board
Please rate this solution
Posted on Jan 18, 2009
racer7x
  • 42 Answers
SOURCE: 53 Hitachi Rear Projection TV with shadows and double images
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Posted on Feb 08, 2009
  • 2920 Answers
SOURCE: double images
you will need to have the tv re converged to make the picture right call a repairman
Posted on Feb 16, 2009
  • 41 Answers
SOURCE: sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Posted on Mar 16, 2009
Double images on screen
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Feb 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
The image of my 53sbx10b are double after few minute
Replace convergence ics. Hitachi has a ki for this consisting of STK-395-110 ic and some resistors.
Apr 13, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 50H81 projection television
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 22, 2008 | Toshiba 50H81 50" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
DOUBLE IMAGE
Convergence system overhaul cost about $400. No mfr. warranty after 90 days to a year unless you bought an xtended warranty for up to 5 yrs. Good set,worth keeping. Senior tech only== careful soldering needed+ OEM or better quality parts a must.
Sep 29, 2007 | Toshiba 42H83 42" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
132 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
