Question about Polaroid i733LP Digital Camera
My camera short circuited!
It was in my friends purse the whole time at busch gardens! She never dropped the purse and it didnt go on the rides. I went to turn it on when i got home and it had a burnt smell and my dad told me it short circuited! I dont how to get it fixed because i dont have the receit or box or any proof i bought it!!!!!!! Help!!!!!!!!!!
    KELBIEE PARISHE May 10, 2008
    STEP 1: get companies address. STEP 2:get a box STEP 3:rap camera up in something thick and put newspaper on all sides of the box and around the camera. STEP 4: write a letter telling exactly what happened if u have receipt put it in there along with the warranty if you have one. STEP 5: get real thick rapping paper and turn inside out and rap around box at least 4 layers or more make sure the design on the rapping paper doesnt show.STEP 6:put address on box and send to company after that relax and wait i no its hard but u have to if u tell the exact story everything will or should turn out right and u.
  • 80 Answers
Buy another one
Posted on Jan 12, 2009
Why is it Blewing 20 amp fuse
You have a short circuit somewhere. Use a multimeter and connect the black lead to the mower chassis. Depending on when the fuse blows start with the most obvious circuit and check for an open circuit to ground. It could be a faulty component or a nearest wire Touching the chassis. Replace or fix these. Work patiently and logically and you will find the fault, it may take some time! Good luck.
Jul 08, 2014 | Husqvarna Garden
A tip and suggestion on using any digital camera.
One of the most two important tips in my experience with digital cameras and the use of them is in the following.
When using a digital camera always take the time to put the hand cord on your wrist. This will help to insure that the camera will not be dropped when using any where, including over or near water. By the way, using any digital camera near water should be done carefully. Water is extremely damaging to the delicate internal parts.
When the digital camera is not in use, always be sure to put the camera in a padded case. I know that it takes more time than dropping into a purse or pocket, but if you take the extra time, you will enjoy your digital camera a lot longer.
By dropping a camera into a purse, you will take the chance of the unit being damaged by other items and possibly turning on from pressure of some item on the on button. This can cause the camera's lens to extend and since it is in a compact area, it can become damaged.
By putting the digital camera into a pocket, you take the chance of the camera falling out and being damaged. It is surprising how many cameras I have had which have been dropped and damaged.
on Dec 18, 2009 | Cameras
Why does my riding mover keep blowing 20 amp fuses?Hus
Short circuit, if it's completely random then it's probably a wire has been worn and is touching the chassis. You'll need a volt meter to find out which circuit and wire (or component) is causing the problem. Check each circuit in turn and be as logical as possible. There are no short cuts.
3/4 of my camera screen is all white and i don't know what could have happened to it because i haven't dropped it, but it has been in my purse for a long time, but nothing in my purse is heavy...
Possible that the LCD screen has failed. You can take images and load them to the PC.,If the images are clean then the LCD is a suspect. remove the battery for sometime and reset. If the fault occurs as a blank screen then the LCD must be taken out and checked for possible damage.
Jul 11, 2011 | Cameras
Dropped in river for about 5 minutes. Later tried to blow(with mouth) all the water I could out. Is it savable? I charged battery but it doesn't turn on now..Any thoughts or help? Also put camera in...
Well, the camera was submerged for 5 minutes as you said, at this point we are talking about a whole circuit blowing/short circuit.
If you are so lucky, it is only the circuit, then you might have to look at the CCD's, and this is just to name i few.
You can try putting your camera into a sealed container filled with 2 cups of rice for about 24 hours. If that doesn't work, it's done.
Kind regards
Aug 30, 2010 | Sony Cameras
My wonderful little sony cyber-shot got drenched when my water bottle spilled in my purse. It was in my purse about 5 minutes when I discovered it wet. I took it out and laid it in my car seat to dry it...
Every time you try to turn on a camera that still has water in it, you fry the circuits. You should have removed the battery and card, dried as much as you could and then buried the camera in a bowl of dry rice for a week before even thinking of trying it.
Aug 10, 2010 | Cameras
Cracked Camera
This depends on your warranty, if it covers cracks and the product being dropped I'm sure they will give you a new one to replace it, or find parts to repair it.
Sep 10, 2009 | Cameras
My lawnmower quit mowing.
It depends on whether its a lever or pushbutton engage model? it may be a broken belt or a simple wire connection come loose. If you want to stay friends tell them mowers are repairable/replaceable but friends arent!
Aug 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
Aug 08, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Z20fd got wet in my daughter's purse
If an electronic device gets wet or is submerged, DO NOT TRY TO TURN IT ON! In most instances,this short circuits/damages the device. If you let the device dry for 3 to 10 days, it may clear of moisture, and work without short circuiting. If the device was immersed in fresh-water, that is.
If it was immersed in salt water, the likelihood of damage and failure is almost guaranteed.
Mar 26, 2009 | Fuji Finepix Z20fd Digital Camera
Polaroid i733LP Digital Camera Logo
74 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
