Question about ASUS A8V-VM Motherboard
Asus a8v-vm se fans always run
I recently purchased an asus a8v-vm se and as soon as i plug in my power supply the fans start running even when system is is shut down. everything else seems to work fine system boots no errors.
I replaced power supply but problem still occurs.
Posted on Apr 02, 2008
  • Joe Patch
    Joe Patch Mar 16, 2013
    Your power switch is sticking on the front, open the machine and follow the wire from the front and unplug it ,just pull it off, and see if it stops.
  • 2,351 Answers
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Posted on Mar 31, 2008
Asus A8V-XE motherboard keeps shutting down, just put new power in and it is still doing it
Kindly see if the CPU fan is working properly. This might be a system shutdown due to overheating components
Hope it helps..
Thanks for reaching Fixya.
Leave comments for further assistance.
Apr 03, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
My pc audio isnot coming pl do sugest us how to down load model asus A8V - VM SE E2928 drivers I could find hope this helps.
Mar 12, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Motherboard flashes when power cord plugged in
I had the same issue with the same mb. The cpu has gone bad. rare, I know, but it happens.
Dec 15, 2009 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asus motherboard a8v-vm jumper setting motherbord on but cpu fan not ON
You do not use a jumper to run the CPU fan. There will be a small 3 or 4 pin plug near the CPU mount and you can plug the wire from the fan into that plug only. If the one on the motherboard has 3 pins and your plug has 4, you can use it anyway; just be sure the slot on the back of the plug matches the side of the one on the board.
Oct 28, 2009 | ASUS A8V-VM Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
Dont forget to rate the advice.
Aug 03, 2009 | ASUS A8V-VM Motherboard
Hi sair mere pas asus a8v-vm se motherbord ka adio driver[alc660]nahi hai pls help.
Hello jee,
App iss link se apke drivers download kar sakte hain.
ASUS a8v-vm se
Bas apni operating system select kijiye aur apne motherboard ke drivers download kijiye.
Mar 10, 2009 | ASUS A8V-E SE Motherboard
ASUS A8V-VM Motherboard Logo
171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
