Question about KitchenAid Dishwashers
Kitchen Aid Built in Dishwasher....KUDS01DJSS0 HELP!
Dishwasher worked fine for five years. Emptied dishwasher, closed door, heard clicking sound for about 30 seconds and now is stuck. Rinse Only light flashing. No controls work. Have tried flipping circuit breaker overnight, still does not reset.
Purchased new control board, installed and when power is turned back on, cycle 2 shows in display and then clears and normal light blinks. Still no controls work.
Any ideas?
SOURCE:
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 1665 Answers
SOURCE: Filling the rinse aid compartment
Download your free instuctions manual here
http://www.devicemanuals.com/userguidesearcher.php?search=sl
Posted on Feb 05, 2008
reg501
  • 413 Answers
SOURCE: Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 10, 2008
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Dec 16, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Nov 13, 2008 | Kenmore 24 in. 15652 Built-in Dishwasher
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
202 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
