Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Is it possible for the belt to stretch out so much that it won't engage the blades. It worked last year and now it doesn't. I have looked at all the obvious possible problems and it appears that none of the springs are broke or missing. The belt has at least two to three inches of slack even when engaged.
    Scholar:
  • 108 Answers
Your belts will stretch out and only have a life span of 1 or 2 seasons. There should be nearly no slack once the blades are engaged. Make sure it didn't slip off any of the pullys and the belt tensionor is on correctly. Check belt for cracking or fray makrs on edges as these are clear signs of a worn belt.
Posted on May 14, 2010
My blades won t engage on my yta22v46 husquvarna riding mower
Is the belt connected? Stretched? On Pulley?
Apr 09, 2017 | Garden
My problem is with a Webb H12R-A manual lawn mower which has the blade set on the lowest setting possible but doesnt cut the grass
Are the blades turning when you lower the deck? If not, your belt may be slipping or it's off the pulley. Once you lower the deck and lift your foot off the the brake / clutch it should engage because the slack is now taken up on the belt, so slipping, belt jumped off or belt stretched out.
Aug 30, 2016 | Garden
Snapper 23 series mower blade will not engage
sounds like you belt is disengaged or just wore out, these type belts look good just to look at them, but they can stretch and get rounded a little bit of can mean a lot
Apr 05, 2014 | Snapper Garden
Dixon speedztr belt is loose when I try to engage won't work
look to see if the belt is on all the pulleys and all the linkage rods are in place
Apr 20, 2012 | Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
You have to hold the mower blade engagement lever, which engages the mower blades to turn.Poulan model PXT12530
sounds like the belt is stretched, check the belt or get a smaller belt, doesnt take but a quarter inch to effect engagement
Sep 25, 2009 | Poulan Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Shredding belts
first make sure the belt is not hitting anything when the blade is engaged (engine off), the if ok remove belt and look in pulley grooves for rocks or chips., then run finger all around groove to make sure there is no catches or spurs. If that is all ok then with belt on and engine idleing as slow as possible and blade engaged look and see if pulley is wobbling, BE CAREFULL !! look at the engine pulley first then with EXTREME CAUTION look under deck from opposte side of chute. ( Check with deck at highest setting)
Jul 24, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
142 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
