Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. When i release the button the garage door opens back and clicks 10 times
    President:
  • 3,197 Answers
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them is shorted or broken.
Posted on May 13, 2010
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
Our garage door will not open all the way. Up until yesterday it worked fine. Then when I came home from work and pushed the button to open the door, the door raised up about 3 inches and stopped. I pushed...
You have either a broken door spring or the drive gear in the motor unit is bad. The drive gear is a white nylon gear just in front of the motor and it will be obvious if it is bad.
Nov 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. when i release the button the garage door opens back and clicks 10 times
Check your door sensors. The need to be pointed at one another and make sure the small light on each one is lit and not flickering. Tweak them a bit. If you can't get both lights to come on one of your sensors has failed.
Mar 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Won't shut off unless the door is opened
Usually the only thing that will stop the dryer is to open the door or turn the timer to the off position.
Nov 24, 2009 | Dryers
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Chrysler T&C Power Door Problem
If it stops in roughly the same spot every time, and won't respond after it has stopped, it sounds like a broken wire. It is likely losing its electrical current to run the motor. It should be right where the track bends when the door has stopped. Check for loose or frayed wiring inside the flexible plastic track just below the door. The wires will often wear after being bent over and over again. If you find a broken bit of wire, cut out that section and splice in a new length of wire. Be sure you do a good job splicing, or you may end up with the same issue again soon. I am not a mechanic by any means, this just makes sense to me, and I'm considering buying an 01 town and country with this issue, which is why I'm on this site to begin with. Best of luck -
Jan 22, 2009 | 2008 Chrysler Town & Country
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
53 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
