Question about Dell 922 All-In-One InkJet Printer
Printer reads cover open
The printer display screen reads cover open. I tried to turn the printer off and turn it back on but it won't power off. I unplug it and then plug it back in and it stills reads cover open. I am not sure what cover it is referring to because the cover is not open. After Fixing form feed (by turning printer upside down&shaking untill all rattling stopped then removing a few alien objects) I had to replace dried out ink cartridges. Then I had cover open message. I then heard a new rattle and shook out a black plastic arm/switch thingy. It is 1-1/8" long by 1/4" wide by 3/8" high on deepest point. I released the cover at hinge side catches so it would open fully. I can see a small port on the upper cover with a spring exposed. The arm thingy is a good fit but I can't figure how to snap it back in. Part appears to have no broken edges. How/where can I reinstall this part?
  • 3,037 Answers
Could you take a picture of this part and the place that it goes and post it on here so that we can better help you out, otherwise I would go to a printer repair shop that could probably pop it in within minutes. If you want an address/phone number of a repair shop, just give me your city and state or country and I can assist further but there is no diagram for this printer online and I don't own one so if you can put a couple of pictures online or wish to take it to a shop, please let me know, thank you
Posted on Mar 29, 2008
  • 796 Answers
Have you tried to reset the computer...
or there must be some problem in the controller
try to flash and reprogram it
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Screen displays message saying "cover
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
  4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first.
  7. Reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Ink system faillur hp offiejet 6500
Try these steps submitted by another user on FixYa:
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
10. If the error is still there Try below:
1. Get the unit into the "Support Menu" by following the steps below
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
14. If the error is still there, or reoccurs replace the unit.
Regards GM
Apr 22, 2011 | HP Officejet 6500 Wireless All-in-One...
Ink system failure
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
  • If the error is still there continue reading...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | HP DeskJet 5150 InkJet Printer
I have an error message on my printer "Error:0x07a74dd6" please advise
4. Disconnect the power cord from the back of the product and wait for one minute.
8. Reconnect the USB cable, and try to print a print job from the computer
if it don't work then try this
1.Firstly if the printer is connected to a surge protector or any kind of power strip disconnect it from there and connect the printer directly to the wall jack.
2.Even after that if it is not working then you can perform a factory default reset on your machine
a) Leave the printer turned on and then disconnect the power cable from the printer and then press and hold the # and 6 together at the same time while plugging the power cord to the printer and keep on holding the buttons once you see semi-full reset
See whether it works or not
b) In case if it does not work then perform the same thing but instead of # and 6 press and hold # and 9 and the display will read full reset
3.Also try to connect the printer in a different wall outlet and if possible try with different power cable
Mar 17, 2010 | HP OfficeJet 7310 All-In-One InkJet...
HP Photosmart D7260 Ink System Failure Error 0xc18a0206
1. Disconnect the Universal Serial Bus2.gif (USB) cable from the back of the product, but leave the product turned on.
10. If the error is still there replace the unit
1. Get the unit into the “Support Menu” by following the steps below
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen2.gif)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure2.gif” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Good Luck
Oct 20, 2009 | Office Equipment & Supplies
Hp photosmart 3210 problem
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Jun 29, 2009 | HP Photosmart C7180 All-In-One InkJet...
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ink System Failure - 0xc19a0035
Dec 14, 2007 | HP Photosmart C7180 All-In-One InkJet...
Dell 922 All-In-One InkJet Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
