Question about Toys
Bladez helicopter, I'm trying to replace the
Bladez 3d rc helicopter I'm trying to replace the balance bar how do I get the connecting pin out?
  • 748 Answers
Hi
I'm sure you're talking about that very small, steel pin located in the main shaft. The most efficient way is to lay the rotor head on a flat surface. I put a steal hut much bigger than the pin behind the pin to support the shaft. I then use an awl and a hammer to tape out the pin. Never reuse an old pin. If they're bent in any way that bend will force the shaft to bend when reinserting it. Good luck
Posted on May 13, 2010
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four...
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Dec 28, 2013 | Shuttle 9094 Emax Remote Control...
F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
Dec 31, 2012 | Bladez Exercise & Fitness
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
I have the fastlane hawk 4 and my balance bar broke, how and where can i find a replacement part?
you can find replacement balance bars for the Fast Lane Hawk 4 rc helicopter from WAYNENIK on eBay!
Jan 12, 2012 | Toys
Rc 3 channel apache helicopter how to replace balance bar without the tool kit provided
Cut the balance bar off until the pins are exposed. Use some pliers and squeeze the pin out and then put the new balance bar back on and put the pin back in.
I did it this way without the tool kit, my balance bar was already broken so it wasn't an issue to cut it. It worked for me, I am flying it right now.
Jan 02, 2011 | Apache RC Mini Helicopter AH-64
How do i get the pin out of balance bar assembly. part of the bar broke of in a crash. i have a new bar.
Where did you get your new balance bar? I have the UJ415 apache and broke the black balance bar off within 10 minutes but can't find a replacement? Thanks!
Sep 12, 2010 | Apache RC Mini Helicopter AH-64
Remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
Apr 18, 2010 | Apache RC Mini Helicopter AH-64
How do I change the clutch belt on my BladeZ Moby motorized foot scooter (25CC)? Do you have any instruciton manual type pictures as I can't download any from the manufacturer?
there are 4 bolts that hold the engine in place on the left side of scooter when your looking straight towards the bars
then there are 3 more bolts below those tak em all all be carefull not to loose the small spacers behind the large ons there hard to notice but they are there
slip you belt over both pulleys and reasemble using the 2adjustment screws that attach to the big pulley on bottom until the belt is 110 & straight and has a little bit of play abotu half in or so should be fine you dont wat too much other wise it will break if you hit a bump or whatever an if its too loose wellit will slip as you might know
Jul 15, 2009 | Bladez 320-5M/25 Clutch Belt for BladeZ...
Toys Logo
342 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
