SOURCE: kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
Here is some additional info that could be helpful.
Click HERE
SOURCE: lights come on, not cooling, temp indicator shows (-)
Because your digital controls appear to be confused I think the electronic module behind the temp control is defective. The part number for your control board is 12868513
You can enter the model number JFC2087HRP in model and parts search feature at the link below. You may want to unplug refrigerator and examine the part for burn marks or other signs of damage. Let me know what you find, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Compressor stop running on Kenmore
Hi and welcome to FixYa. I am Kelly
Is the compressor HOT to the touch? If so unplug the unit for at least 30 minutes and plug it back in.
If the compresor is cold then it may be stuck in the auto defrosting mode. When this happens usually either the 60 Deg F Bi-metal thermosat or a thermistor has failed. Items 30 and 31 this link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
(Evaporator
If that checks out then we start replacing the PTC relay and thermal overload on the compressor IF there is power to the compressor. Otherwise we start looking at temp controllers and themal fuses.
Items 10 and 11 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00011?blt=06&prst=&shdMod=
You make have to access the links above via this page http://www.searspartsdirect.com
Then enter your model number as 596.75523400 under find it fast / model search.
The other possibility is the electronic control item 5 under "controls":
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00006?blt=06&prst=&shdMod=
The only way to find out is to read out the circuits with a meter.
Thanks for choosing FixYa
Kelly
SOURCE: I have a Kenmore model
Hi, If
you are hearing a clicking or buzzing then check out the last two
tips.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
SOURCE: kenmore elite model #596 76594600
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
