what your problem is that the printer is out of ink. this problem evens happens with laser printers. most people don't relise that laser does have a ink cartrige in it also. these may on the pricey side too.
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Normally the symbols indicated require attention some times a triangle with little dots in the triangle
need to have the waste toner emptied from machine hope this helps you it depends what is being shown in the triangle a zig zag with may be two circles in the triangle would be like jammed paper needs to be removed
1. Press-and-hold down the button with the 'Dot' - allows access to configuration options 2. Press the 'forward triangle' button repeatedly until the screen reads 'Set units (km/h) - or mph 3. Simultaneously press the Dot & Forward triangle buttons - allows you to edit settings 4. Press the Dot button to select the units of your choice 5. Simultaneously press the Dot & Forward triangle buttons to accept changed settings
